found grease on passenger side cv axle
Old 03-17-2013, 02:26 PM   #1
lohrryan [OP] lohrryan is offline
lohrryan is on a distinguished road
lohrryan's Avatar
Army: Ch-47 chinnok flight crew member
lohrryan's Tacoma Gallery
i was changing my oil today and when i went to remove the drain plug i noticed grease on my lower control arm and i started looking around and the only other place i saw any was on the cv axle the grease was pretty liquefied and thin it was mostly on the top of the boot except where it ran down on the lca after cleaning it i didn't notice any and cracks or tears on the boot its self any suggestions on what it would be????
sorry tried to rotate pictures but it wasn't working
Old 03-17-2013, 02:41 PM   #2
Buckoma is one of the sharper tools in the shedBuckoma is one of the sharper tools in the shedBuckoma is one of the sharper tools in the shedBuckoma is one of the sharper tools in the shedBuckoma is one of the sharper tools in the shedBuckoma is one of the sharper tools in the shedBuckoma is one of the sharper tools in the shedBuckoma is one of the sharper tools in the shedBuckoma is one of the sharper tools in the shedBuckoma is one of the sharper tools in the shedBuckoma is one of the sharper tools in the shed
Buckoma's Avatar
Army: MI Officer
Buckoma's Tacoma Gallery
Replacing a boot is a crap job, probably easier to get a new CV.
Is your power steering res oily?
Old 03-17-2013, 03:13 PM   #3
lohrryan's Avatar
no its not its clean and it just started doing this because i changed uca and there was nothing there when i did that
Old 03-17-2013, 03:15 PM   #4
braaap
steve o 77's Avatar
steve o 77's Tacoma Gallery
I ran mine with a leaky boot for over a year, not a problem. I eventually replaced it with a vatozone lifetime warranty axle.
Old 03-17-2013, 03:16 PM   #5
Power Top
MonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shedMonkeyProof is one of the sharper tools in the shed
MonkeyProof's Avatar
Army: K9 Handler
Gender: Tranny
MonkeyProof's Tacoma Gallery
Send a message via MSN to MonkeyProof Send a message via Skype™ to MonkeyProof
Here you go..
http://www.tacomaworld.com/forum/2nd...-c-v-boot.html
Old 03-17-2013, 03:40 PM   #6
lohrryan's Avatar
thanks guys ill probably end up replacing both cv axles i was having the the problem with the front end shake around 55mph caused by the crappy bearing and had already bought the replacement bearing from east cost gear so replacing them seems like the best option for me but since i just spent over a grand on my truck i was trying not to spend to much money what would be the best replacement axles for the money oem or after market also will it be ok to run it for awhile with the torn boot i wont be doing much wheeling anytime soon?
Old 03-17-2013, 03:46 PM   #7
Power Top
Army: K9 Handler
Gender: Tranny
Why would you replace the cv with crappy Chinese ones and loose the strength of the 30 spline OEM which is as strong as a Dana40 axle. Replacing a torn CV boot is fairly simple provided you have the proper tools
Old 03-17-2013, 03:57 PM   #8
lohrryan's Avatar
OK so just replace the boot and when i decide to replace the axle go with oem
Need Help. Removing Driver Side CV Axle! bjmoose 2nd Gen. Tacomas 37 02-12-2014 04:58 PM
CV Axle leaking grease (not ripped fins) pyroskier 1st Gen. Tacomas 14 12-16-2011 04:43 AM
Feeler: New 2005+ Tacoma CV Axle (Driver's side) Muy Grande Texas 12 10-27-2011 12:39 AM
Noise from front passenger side found! 18thstlocal 2nd Gen. Tacomas 0 03-14-2011 10:12 AM
Grease down passenger side?? DFPTaco 2nd Gen. Tacomas 9 10-24-2008 06:56 AM
