Tailgate Assist
Discussion in 'Technical Chat' started by ADKer, Mar 25, 2013.
  1. Mar 25, 2013 at 10:35 AM
    ADKer
    ADKer [OP] North & South
    ADKer
    Savannah, GA & Saranac Lake, NY
    Read threads on this subject from years back. Interesting, thanks!
    Info ... there are still new, in the wrapper, kits available on ebay; someone must have purchased lots of DeeZee stock when they discontinued production of the kits for Tacomas.
    More importantly, there were issues with the stock cable binding and wearing with the kit installed. DeeZee resolved this on newer kits by adding a "cable clip". This is barrel shaped rubber clip that snaps onto the stock cable preventing it from wedging between the truck body and the pneumatic cylinder of the kit.
    Just installed mine, works great, no cable problems ... wish it were a Toyota option!! ;)
  2. Mar 27, 2013 at 1:26 PM
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    I want a tailgate assist... :( cant find any out there
  3. Mar 27, 2013 at 5:21 PM
    ADKer
    ADKer
  4. Mar 28, 2013 at 9:47 AM
    EDJY
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    link doesn't work...
  5. Jun 24, 2013 at 12:16 AM
    squatnbear
    squatnbear Well-Known Member
    TX pro MGM
    Just ordered one the link is working.
  6. Jul 14, 2013 at 10:02 PM
    Frost2012
    Frost2012 New Member
    Dallas
    12 PreRunner SR5
    is there a tailgate assist for a 2012 tacoma? Can't find any online.
  7. Jul 15, 2013 at 7:41 PM
    lasllc
    lasllc Wait. . what’s wrong here
    Southwest RedRocks
    13 SuperWhite DCSB Sport TRD
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
  8. Jul 16, 2013 at 2:28 PM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    Icon/TC Mid travel, TRD S/C, PNP Greddy EMU, 625cc injectors, 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    No love for the first gens...
  9. Jul 16, 2013 at 2:56 PM
    tacomalimited
    tacomalimited Well-Known Member
    Northern NJ
    2018 tacoma limited double cab Short bed 4x4.
    I didn't see it for the '12 our '13's either! The latest year I saw was 2011. Are the 2011 tailgates that much different from the 2012 & 2013's?
  10. Jul 16, 2013 at 8:03 PM
    lasllc
    Southwest RedRocks
    If you check the hood lift page there is an option to add on the tailgate with a discount. Either the applicability data base is out of date or the '11 will fit '13 or neither is correct
    http://www.redlinetuning.com/QL-TOY-TACOMA-95+.html
    ""2005-2013
    Our Price: $69.95
    Model #21-27010
    Tail-gate EZDown option available for 05-13 Tacoma, savings of $15 when purchased together using the link above. For more informationon EZDown, visit our parts page...""
  11. Jul 23, 2013 at 4:17 AM
    hpeeler
    hpeeler Active Member
    What size torx bit do you need to get the tailgate bolt off? I tried 5mm but it didn't fit real well. Maybe it's not torx?
  12. Jul 23, 2013 at 7:24 AM
    lasllc
    Southwest RedRocks
    Will be back later with torx size; I was not using a ratchet and bit so needed a bit of a cheater.
    Note that the E-Z Down would not work on my '13 sport. Insufficient Clarence on either side of the cylinder. Could make it work but would need to force the gates shut and jam the cable. Removed it.
  13. Jul 23, 2013 at 10:07 AM
    hpeeler
    I found the right size.
    Yeah I found this out too. I have to push the cable to the side of the cylinder to get it to close. Not sure if I will keep it or not.
  14. Aug 24, 2013 at 7:12 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I see I can get the old one for $30 like you did. What did you do to duplicate the part on newer kits by adding a "cable clip". This is barrel shaped rubber clip that snaps onto the stock cable preventing it from wedging between the truck body and the pneumatic cylinder of the kit. Thanks.
