1998 Taco, persistent p0306, ECU?
Old 05-13-2013, 05:08 PM   #1
RyJones [OP] RyJones is offline
RyJones is on a distinguished road
RyJones's Avatar
RyJones's Tacoma Gallery
Hi,
V6 1998 TRD, lightly abused for 135k miles. Throwing 0306, had plugs, wires and bunch of other stuff replaced. Ran OK for 300 miles then back to rough running with CEL.
After a while, it goes open loop and runs OK for 10 minutes or so.
Since plugs and wires are new, what's next? ECU? Don't trust the shop that took $1650 to not fix the issue to take another go at it (they took care of other issues, so it wasn't a waste of time)
Old 05-13-2013, 09:16 PM   #3
RyJones's Avatar
Good call on the injectors; I forgot to mention they blew a can of injector cleaner through 6. That doesn't mean that injector is gtg, though.
I don't know that they checked compression. Would bad compression come and go like that?
Old 05-14-2013, 07:10 PM   #4
ASE Master Tech
BamaToy1997's Avatar
BamaToy1997's Tacoma Gallery
Depends on the cause of the low compression. Sticking valves can cause periodic low compression.
Old 05-14-2013, 09:21 PM   #5
RyJones's Avatar
Thanks. Hopefully I can find a mechanic to look at it - the one I used for years retired, and the new guys aren't cutting it.
Jet Performance Upgraded ECU 2001 V6 taco 4wdmofo 1st Gen Tacoma Marketplace 8 10-25-2012 09:14 PM
Persistent fever 09_tacoma Health 24 07-07-2012 08:00 AM
Persistent Engine Shudder (2001 Tacoma) tacoma97 Technical Chat 1 11-03-2011 05:03 PM
persistent scraping noise from steering wheel pebbles Technical Chat 26 10-27-2010 05:18 AM
How do I reset my 2009 taco ecu? TodaGuy 2nd Gen. Tacomas 7 01-03-2010 05:27 PM
