05+ 4wd Replacing u-joints, greasable or sealed?
Discussion in 'Technical Chat' started by Sandman614, May 24, 2013.
  1. May 24, 2013 at 7:36 AM
    Sandman614
    Sandman614 [OP] Ex-Snarky TWSS elf, Travis #hotsavannahdotcom
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    It's about time I replace my u-joints. I finally got around to greasing them and some nice rusty looking water came out. :eek: I've heard Spicer is "the word" when it comes to u-joints, Dana uses them from factory. Is there another good brand? How are the Tom Woods Gold Seal?
    I know Toyota put greasable ones in for the 4wd models. Should I just stick with greasable or go with a sealed one?
  2. May 24, 2013 at 7:51 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    i'd stick w/ greasable. i've seen more people on here have issues w/ the sealed ones.
  3. May 24, 2013 at 8:12 AM
    BradyT88
    BradyT88 Well-Known Member
    Sealed ones are good for 75K-100K miles and then your driveshaft explodes... Ask the pre-runner guys, there's been a few threads on hear about it. I would just get the greasable ones and grease them.
  4. May 24, 2013 at 8:13 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I would never get sealed. Mine have a slight bit of slop after over 90k. If you take care of them they will take care of you.
    I flush mine out of the old grease every time I grease them. I don't stop pumping slowly until the grease turns clean.
    I carry 4 brand new Moog super strength joints in my spare parts bin with some old pulleys and a old belt just in case.
  5. May 24, 2013 at 8:17 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    What kind are they? I've seen 1330 but that was on a prerunner thread.
  6. May 24, 2013 at 8:20 AM
    XXXX
    sKiP
    05 Prius
  7. May 24, 2013 at 8:28 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    This^ there is a lot of miss information when it comes to greasing U joints most just pump until you see the dirty grease coming out. I too pump slowly until clean grease comes out and ive never had a U joint failure on anything ive owned. They say non greasable are stronger but i dont see any issues running a greasable U joint.
  8. May 24, 2013 at 3:07 PM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    I want to be able to put some grease in those caps after I take them off and hammer them into the driveshaft!
