Drilling a bigger hole in 3/16" steel
Old 06-08-2013, 08:38 PM   #1
tomtom [OP] tomtom is online now
tomtom is one of the sharper tools in the shedtomtom is one of the sharper tools in the shedtomtom is one of the sharper tools in the shedtomtom is one of the sharper tools in the shedtomtom is one of the sharper tools in the shedtomtom is one of the sharper tools in the shedtomtom is one of the sharper tools in the shedtomtom is one of the sharper tools in the shedtomtom is one of the sharper tools in the shedtomtom is one of the sharper tools in the shedtomtom is one of the sharper tools in the shed
tomtom's Avatar
tomtom's Tacoma Gallery
The skidplate holes on my Elite bumper aren't big enough:
Is there a best or good way to drill them out bigger? Is there a special bit for this type of job? Is there a good technique?
I have a hand drill and some experience and drilling steel. Since it is attached to the bumper, not going to be able to stick it in a press.
Old 06-08-2013, 08:44 PM   #2
Solid Axle FTMFW!!
Supra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shedSupra TT is one of the sharper tools in the shed
Supra TT's Avatar
Supra TT's Tacoma Gallery
The hole looks elongated... Not sure if there is any good way to drill that out. But if you just needed it drilled out for a hole you can use the correct size metal bit to drill it out. Just be careful since it'll want to grab and twist your wrist. Use some lube too, never hurts to use lube in the bit
Old 06-08-2013, 08:48 PM   #3
OZ-T's Avatar
OZ-T's Tacoma Gallery
Hole at each end and file
Old 06-08-2013, 08:51 PM   #4
Solid Axle FTMFW!!
Supra TT's Avatar
Never thought of that.
Old 06-08-2013, 08:53 PM   #5
Rabid Conservative
majorhavok is one of the sharper tools in the shedmajorhavok is one of the sharper tools in the shedmajorhavok is one of the sharper tools in the shedmajorhavok is one of the sharper tools in the shedmajorhavok is one of the sharper tools in the shedmajorhavok is one of the sharper tools in the shedmajorhavok is one of the sharper tools in the shedmajorhavok is one of the sharper tools in the shedmajorhavok is one of the sharper tools in the shedmajorhavok is one of the sharper tools in the shedmajorhavok is one of the sharper tools in the shed
majorhavok's Avatar
Name: Mike in Cali..
majorhavok's Tacoma Gallery
+1, although a dremel would be faster and my first choice to enlarge the slot.
Old 06-08-2013, 08:54 PM   #6
OZ-T's Avatar
I hate Dremels
Old 06-08-2013, 08:58 PM   #7
Deercantseeme is one of the sharper tools in the shedDeercantseeme is one of the sharper tools in the shedDeercantseeme is one of the sharper tools in the shedDeercantseeme is one of the sharper tools in the shedDeercantseeme is one of the sharper tools in the shedDeercantseeme is one of the sharper tools in the shedDeercantseeme is one of the sharper tools in the shedDeercantseeme is one of the sharper tools in the shedDeercantseeme is one of the sharper tools in the shedDeercantseeme is one of the sharper tools in the shedDeercantseeme is one of the sharper tools in the shed
Deercantseeme's Avatar
Army:
Deercantseeme's Tacoma Gallery
Start drilling the hole in reverse. That way it won't grab and twist around or chip the edges of the drill bit off.
Old 06-08-2013, 08:59 PM   #8
tomtom's Avatar
I'm installing a Budbuilt skidplate and it has elongated holes on it. I should just be able to drill a hole on the bumper tab and the skidplate will give me the play to line everything up.
Unsure of the details but was thinking of clamping some wood or sheet metal on it to start the bit and keep it from jumping. Figured I'd ping you guys that have done more extensive fab activities.
Old 06-08-2013, 09:06 PM   #9
Rabid Conservative
majorhavok's Avatar
I hate Dremels
One steal your girl when you were younger? lol
Depends on the job, but I do a lot with a dremel.
My favorite bit:
http://www.amazon.com/SE-DW13-Diamon...l+diamond+bits
Old 06-08-2013, 09:12 PM   #10
OZ-T's Avatar
My favorite bit:
Just underpowered
Old 06-08-2013, 09:21 PM   #11
llibrm is one of the sharper tools in the shedllibrm is one of the sharper tools in the shedllibrm is one of the sharper tools in the shedllibrm is one of the sharper tools in the shedllibrm is one of the sharper tools in the shedllibrm is one of the sharper tools in the shedllibrm is one of the sharper tools in the shedllibrm is one of the sharper tools in the shedllibrm is one of the sharper tools in the shedllibrm is one of the sharper tools in the shedllibrm is one of the sharper tools in the shed
llibrm's Avatar
llibrm's Tacoma Gallery
your need a grinder. A dremel will work the same way. I don't recommend a drill though. It will want to catch every 90*
Old 06-08-2013, 09:36 PM   #12
OH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shedOH-MAN is one of the sharper tools in the shed
OH-MAN's Tacoma Gallery
Just underpowered
I agree completely Dremels are for arts and crafts projects not manley steel and iron!!
I do have one that my wife uses for her card making class!
Old 06-08-2013, 09:44 PM   #13
Rabid Conservative
majorhavok's Avatar
Just underpowered
Try these, torquey as hell:
http://www.mcmaster.com/#catalog/119/2609/=n41531
Old 06-08-2013, 09:48 PM   #14
OZ-T's Avatar
I have the 4000 model
Blah
Old 06-08-2013, 10:22 PM   #15
Rabid Conservative
majorhavok's Avatar
Blah
Sorry, my link didn't have P/N. Not the dremel brand, the torqueshaft ones with foot pedal:
Drilling a bigger hole in 3/16" steel-grinder.jpg
BFG Rugged Trail tires 265/70/16, 16" steel wheels iamsuperbleeder Wheels & Tires Marketplace 5 02-23-2013 02:25 PM
Want To Buy Black steel wheels, 16" or 17" NinjaT1985 Wheels & Tires Marketplace 9 01-08-2013 04:25 PM
Drilling a hole in my roof IndianTaco 2nd Gen. Tacomas 64 04-21-2012 07:36 PM
New 16" Blk Steel Rim, Brand New Tire Dunlop 245/65/16 jfjacques 2nd Gen Tacoma Marketplace 1 01-04-2012 09:36 AM
Recommendations: Bigger tires on 16" wheels mjt4d Wheels & Tires 3 02-10-2010 04:45 PM
