4wd dash light blinking , 4wd not engaging
Old 07-07-2013, 02:25 PM   #1
mxxdude [OP] mxxdude is offline
mxxdude has a spectacular aura aboutmxxdude has a spectacular aura about
mxxdude's Avatar
Army: Military Police
mxxdude's Tacoma Gallery
My 4x4 in my 2006 Tacoma was working fine the other day, today I got in the truck and the 4x4 light on the dash was blinking in 2wd , tried to engage it in every way didnt work, when I put it in 4 Lo no beep or 4lo light , and the dash light is constantly flashing .
No sounds come from the truck when I try anything
Checked the fuse by the left knee and replaced it and now I'm stuck truck has 62xxx miles
Old 07-07-2013, 03:29 PM   #2
Remember Your ABC's. Always. Be. Cool.
Bsheriff11 is one of the sharper tools in the shedBsheriff11 is one of the sharper tools in the shedBsheriff11 is one of the sharper tools in the shedBsheriff11 is one of the sharper tools in the shedBsheriff11 is one of the sharper tools in the shedBsheriff11 is one of the sharper tools in the shedBsheriff11 is one of the sharper tools in the shedBsheriff11 is one of the sharper tools in the shedBsheriff11 is one of the sharper tools in the shedBsheriff11 is one of the sharper tools in the shedBsheriff11 is one of the sharper tools in the shed
Bsheriff11's Avatar
EMS:
Bsheriff11's Tacoma Gallery
Check the 4X4 actuator black box located behind the transfer case, a lot of people report moisture/grime get inside. The fix is to remove the cover, clean it out, and solder the connections together as they are just free inside the actuator. There is a guide here somewhere.
Old 07-07-2013, 08:48 PM   #3
mxxdude's Avatar
Thanks I saw the black box the actual electrical connection was dirty so I cleaned it out hoping it would fix it but no go Tommorrow ill have to take it off
Old 07-08-2013, 09:30 AM   #4
Bsheriff11's Avatar
EMS:
Yea take it off and clean the inside really well, then solder those electrical connections on if you have the means, then seal the actuator back up to reduce dirt getting back in there.
Old 07-11-2013, 07:47 PM   #5
Bsheriff11's Avatar
EMS:
Update OP?
Old 07-14-2013, 01:06 PM   #6
mxxdude's Avatar
I took off the entire a.d.d when I was changing my diff fluids and all the connections look good there was alot of water in it so I though that had to be it. Unfortuantly it wasn't and my dash light is still blinking and nothing is engaging
Old 07-14-2013, 03:57 PM   #7
mxxdude's Avatar
Originally Posted by PSU Taco85 View Post
Hmm, check the voltage readings and post them up ill take a look
From the plug that connects to the outside of the actuator or the actuator itself
Old 07-26-2013, 04:52 AM   #8
Sje1124 is one of the sharper tools in the shedSje1124 is one of the sharper tools in the shedSje1124 is one of the sharper tools in the shedSje1124 is one of the sharper tools in the shedSje1124 is one of the sharper tools in the shedSje1124 is one of the sharper tools in the shedSje1124 is one of the sharper tools in the shedSje1124 is one of the sharper tools in the shedSje1124 is one of the sharper tools in the shedSje1124 is one of the sharper tools in the shedSje1124 is one of the sharper tools in the shed
Sje1124's Avatar
Coast Guard: Boatswains Mate
Sje1124's Tacoma Gallery
Mine just started doing this today
Old 07-29-2013, 01:22 PM   #9
mxxdude's Avatar
I'm back from AT today so hopefully ill be able to diagnos this finally Im goin to start with the transaxle actuator
Old 07-29-2013, 04:07 PM   #10
erockstacoma is on a distinguished road
erockstacoma's Tacoma Gallery
Apparently the design of the tacoma actuator is defective like mine is. My 2005 tacoma w/55000k is stuck in 4wd hi with light flashing 4lo. dealer wants $1600 to fix it. already spent $1700 on defective a/c. Dont think I will ever buy another.
Old 07-29-2013, 08:09 PM   #11
mxxdude's Avatar
It's annoying because the light is always blinking in 2hi nothing happens at all when I flip the switch to 4hi or 4lo
I'm going to check the connections to the t case actuator and after that I don't know what the F else to do
Old 07-29-2013, 08:28 PM   #12
Sje1124's Avatar
the t-case actuator is a POS. It's cheaper to just swap in an FJ transfer case than to buy a new tacoma actuator.
Where did you get the FJ transfer case from?
Old 07-29-2013, 09:30 PM   #13
Sje1124's Avatar
a guy down the street from me was selling it since he got rid of his truck and was parting it out. They are readily available in the junkyards though
and ebay, just did this search
http://www.ebay.com/itm/TRANSFER-CAS...36e832&vxp=mtr
Was it a hard conversion?
Old 07-29-2013, 09:51 PM   #14
Sje1124's Avatar
Took a full weekend, but not that bad really.
So not to bad for someone with mechanical skills? Because I have limited mechanical skills lol. Id prob have to pay a shop to install it for me
Old 07-29-2013, 10:13 PM   #15
Sje1124's Avatar
If you have a manual transmission it's alot easier but for an auto you will have to do some cutting and rewelding of the transfer case shifter to get it to fit. Also, hope you wouldn't mind cutting a hole in the floor I doubt you would find a shop that would want to do that, it's not as straightforward as your typical requests
I dont mind cutting on the truck at all. Now welding...not my forte. Lol
Old 07-30-2013, 03:10 PM   #16
CASTRATE is one of the sharper tools in the shedCASTRATE is one of the sharper tools in the shedCASTRATE is one of the sharper tools in the shedCASTRATE is one of the sharper tools in the shedCASTRATE is one of the sharper tools in the shedCASTRATE is one of the sharper tools in the shedCASTRATE is one of the sharper tools in the shedCASTRATE is one of the sharper tools in the shedCASTRATE is one of the sharper tools in the shedCASTRATE is one of the sharper tools in the shedCASTRATE is one of the sharper tools in the shed
CASTRATE's Avatar
CASTRATE's Tacoma Gallery
Where would one go to purchase an fj t case? I want to get one eventually. The stupid little dial thingy drives me bonkers
Old 08-23-2013, 02:29 PM   #17
mxxdude's Avatar
IF anyone still has this problem it turns out it was the elecrical solenoid in the actuator, thats was fried even though it was still firmly connected , just in case anyone was wondering, took it to toyota and since my friend is a lot attendant it was 600 with parts and labor. not as bad as i though
Old 12-07-2013, 08:25 AM   #18
double dee is one of the sharper tools in the sheddouble dee is one of the sharper tools in the sheddouble dee is one of the sharper tools in the sheddouble dee is one of the sharper tools in the sheddouble dee is one of the sharper tools in the sheddouble dee is one of the sharper tools in the sheddouble dee is one of the sharper tools in the sheddouble dee is one of the sharper tools in the sheddouble dee is one of the sharper tools in the sheddouble dee is one of the sharper tools in the sheddouble dee is one of the sharper tools in the shed
double dee's Avatar
Air Force:
double dee's Tacoma Gallery
Does anybody know if the actuator is covered under the 5 year 60k powertrain warranty?
4WD Lo Light Blinking... Has anyone else had this problem HBMurphy 2nd Gen. Tacomas 14 05-16-2014 12:59 PM
HELP..Changed Plugs, 4wd light blinking and wont engage.. KevLot17 2nd Gen. Tacomas 15 12-21-2013 07:54 AM
Help!!! 4WD light blinking and won't go in 4WD! Luv2adventure Technical Chat 8 11-30-2013 09:21 AM
4wd light on dash flashing MarinePhoenix2207 2nd Gen. Tacomas 3 10-15-2011 12:15 PM
4WD not engaging but light is on SmokeyDP 1st Gen. Tacomas 2 01-03-2011 08:37 AM
