Which Toyota's came with rear LSDs?
Old 10-27-2013, 01:33 PM   #1
902taco [OP] 902taco is offline
902taco will become famous soon enough902taco will become famous soon enough
902taco's Avatar
902taco's Tacoma Gallery
I'm looking for Toyota models & production years with would have the same rear manual limited slip differential (LSD) which came stock in the 2005-2007 Tacoma Sports.
I'm thinking of replacing my stock rear open differential with this LSD but before I start searching through salvage yards, I'd like to broaden my search by knowing if any other Toyota's are candidates. I have a 2007 4x4 4.0L 6-speed manual with 3.73 gears.
I know the US 2WD FJ Cruiser comes with a rear LSD but I'm not sure if it's compatible. I'm thinking the 4-Runner and maybe even the Tundra would be a candidate too.
Old 10-27-2013, 09:26 PM   #3
Boost JuNkY is a name known to allBoost JuNkY is a name known to allBoost JuNkY is a name known to allBoost JuNkY is a name known to allBoost JuNkY is a name known to allBoost JuNkY is a name known to all
Boost JuNkY's Avatar
Boost JuNkY's Tacoma Gallery
All sport and sr5 05-08 comes with lsd rear as far as im aware.
Old 10-28-2013, 03:08 PM   #4
902taco's Avatar
My 2007 SR5 didn't come with a LSD in the rear which is why I'm looking for one.
I did figure out that the same LSD was available in Tundra's built between 1999 and 2006. The Toyota part# for the LSD is 41302-34010 and the # for the whole Tacoma LSD 3rd member is 41110-35A70.
So far, it looks like the FJ Cruiser's LSD is not compatible. At least on paper that is.
Old 10-28-2013, 10:35 PM   #5
Weird, must be a american-canadian thing. All SR5 & sport I looked at when I was shopping for my truck had lsd rear end. all pre 09's
Old 10-28-2013, 10:43 PM   #6
tacomataco2 is one of the sharper tools in the shedtacomataco2 is one of the sharper tools in the shedtacomataco2 is one of the sharper tools in the shedtacomataco2 is one of the sharper tools in the shedtacomataco2 is one of the sharper tools in the shedtacomataco2 is one of the sharper tools in the shedtacomataco2 is one of the sharper tools in the shedtacomataco2 is one of the sharper tools in the shedtacomataco2 is one of the sharper tools in the shedtacomataco2 is one of the sharper tools in the shedtacomataco2 is one of the sharper tools in the shed
tacomataco2's Avatar
tacomataco2's Tacoma Gallery
double cab tundra limiteds or something, i got a used one out of a tundra, apparently there are two lsd models. The trd one, and non trd, trd has less slip, clutch packs tightened to 400ft lbs, non trd has clutch packs at 200 ft lbs. you could get this! http://yhst-99618682857744.stores.ya...kazamalsd.html
Old 10-29-2013, 05:36 AM   #7
902taco's Avatar
Thanks for that link. That's a good price! I sent them an email to confirm if their LSD will fit 2nd gens tacos and if they ship to Canada.
Old 10-29-2013, 02:27 PM   #8
902taco's Avatar
unfortunately their LSD doesn't fit the 2nd gens.
Starting to look into the Eaton-Detroit Truetrac. Kinda thinking that since I'll only be saving ~$200 to install a used factory clutch style LSD might as well install a new torsen style for a little more. Ideally I can get my hands on a used factory unit with the complete 3rd member so I can just slap it in without needing to set the backlash. I've never done it before and I'm not confident enough to try for the first time on my daily driver.
Old 11-04-2013, 01:05 AM   #9
byrd has much to be proud ofbyrd has much to be proud ofbyrd has much to be proud ofbyrd has much to be proud ofbyrd has much to be proud ofbyrd has much to be proud ofbyrd has much to be proud ofbyrd has much to be proud ofbyrd has much to be proud of
byrd's Avatar
byrd's Tacoma Gallery
Sports model came factory with mech LSD, SR5 models it was an option you could order. My SR5 has one.
Old 11-04-2013, 01:08 AM   #10
One Tire Fire
Bandit is one of the sharper tools in the shedBandit is one of the sharper tools in the shedBandit is one of the sharper tools in the shedBandit is one of the sharper tools in the shedBandit is one of the sharper tools in the shedBandit is one of the sharper tools in the shedBandit is one of the sharper tools in the shedBandit is one of the sharper tools in the shedBandit is one of the sharper tools in the shedBandit is one of the sharper tools in the shedBandit is one of the sharper tools in the shed
Bandit's Tacoma Gallery
My 2005 SR5 is an open diff. Certified worthless offroad.
Old 11-04-2013, 05:30 AM   #11
902taco's Avatar
lol, I agree fully.
LSDs, Lockers, Other Diff junk, etc Snowman Canada 2 10-29-2013 02:37 PM
Just rear ended -Toyota vs Chevy genxer36 Off-Topic Discussion 46 03-28-2011 06:24 PM
Lockers/LSDs for front diff? 98fourbangertaco 1st Gen. Tacomas 1 07-15-2010 08:33 PM
toyota rear axle compatabilities fireturk41 1st Gen. Tacomas 5 09-04-2009 09:33 PM
