Warped break drums help
Old 11-13-2013, 05:07 PM   #1
JIB83 [OP] JIB83 is offline
JIB83 is on a distinguished road
JIB83's Tacoma Gallery
When I brake on my 02 4x4 I feel a slight stopping and going feeling when I am almost at a complete stop under 5mph. I think its my rear break drums that might be warped. I am pretty sure its not the front because I just did new rotors and pads about a month ago and also my steering wheel doesn't shake at all when im breaking.
Now my question is, do I have to do a complete break job in the rear or can I just swap out the drums? I pulled the drums off a couple days ago and the brake shoes look almost new still.
What do you guys suggest? I want to just change out the drums tonight since I am leaving for Mojave tomorrow early morning and I don't think I will have time to do a full brake job. I already have the drums and shoes though, could I do the drums before the trip and once I get back do the shoes?
Old 11-13-2013, 05:13 PM   #2
revised
TrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shedTrdSurgie is one of the sharper tools in the shed
Navy: HM2
TrdSurgie's Tacoma Gallery
I don't think its your drums.
Old 11-13-2013, 05:33 PM   #3
TACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shedTACO TX is one of the sharper tools in the shed
TACO TX's Avatar
TACO TX's Tacoma Gallery
I doubt it is either. Did you have your rotors turned when put new pads on. There could be pad transfer on the rotors and that is enough to make it feel like it is grabbing and then letting loose. The rotors should be turned or replaced and pads broken in properly. I say deal with it till you get back and have time to do it all right. Return drums and get money back. Be sure and use your parking brake also since your rear brakes are self adjusting. Good luck
Old 11-13-2013, 05:42 PM   #4
They were new rotors and pads in the front.
Also, when I lift up the rear tires and I spin the wheel, I can hear that the brakes rub for about 60degrees of the full 360degees. So for one full rotation, I can hear the shoes rub on the drum for a little less than a 1/4 turn then nothing for the remaining.
Old 11-13-2013, 05:45 PM   #5
TACO TX's Avatar
The drums can be turned also. But if new pads and rotors are not properly burnished and even pad tranfer laid then they can still be your problem also.
Old 11-13-2013, 05:48 PM   #6
Wouldn't that cause my steering wheel to shake though?
Old 11-13-2013, 05:57 PM   #7
OldPhart
bldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shedbldegle2 is one of the sharper tools in the shed
bldegle2's Avatar
bldegle2's Tacoma Gallery
if your previous front rotors were warped, and warped for a period of time before replacing them, the warping action can slowly make the rear drums get slightly 'out of round', causing exactly what you are describing...been there, had it happen...the warping causes pressure oscillation's all through the brakes pressure lines and affects the drums over time..
New drums will help, if you have the time, just take the drums off, have them turned/trued quickly and slam them back on, you really should replace the pads too since the originals could be glazed by now, even if they look like they have a lot of pad left, that can wait until you finish playing...
Cheapest/quickest way is to have them turned, go play, when you come back replace the rear shoes and install the new drums ASAP...
My advise is to do the whole thing, you should be able to do this before you leave in the morning, pull an all nighter, then go play...
Old 11-21-2013, 12:14 PM   #8
00PreRunner is on a distinguished road
00PreRunner's Avatar
00PreRunner's Tacoma Gallery
I have the same problem in my tacoma. At least one rotor is warped and has lead to warped drums. Both are easy to replace, which is what I would recommend.
Old 11-22-2013, 09:10 AM   #9
tan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shed
tan4x4's Avatar
tan4x4's Tacoma Gallery
Try adjusting the rear brakes following FSM steps (also included in Haynes manual) .There are 3 items that need to be adjusted for the rears to work properly. No cost, just time. Do that before throwing new, un-needed parts at it.
First there is the star wheel adjustment, maybe one is too tight and needs to be backed off.
There is an adjustment to the e-brake bell-crank (at the end of the e-brake cable outside of the backing plate).
Then the e-brake 'click count adjustment' (adjustment nuts are under the driver-side of the body).
Warped rotors -- cant get this issue to go away Peru 2nd Gen. Tacomas 39 07-18-2014 06:05 PM
Warped Rotors / Drums cstallings 2nd Gen. Tacomas 96 03-26-2014 10:45 AM
Warped Rotors MiamiLaker New Members 2 05-16-2012 04:03 AM
Warped Rotors Dimonback 2nd Gen. Tacomas 27 07-13-2011 06:32 AM
Warped discs again. glennv General Automotive 9 04-10-2010 12:36 PM
