How To: Spark Plug Change (1 GR-FE)
Old 06-28-2013, 03:26 PM   #1141
Christ Follower
RadRed06 is one of the sharper tools in the shedRadRed06 is one of the sharper tools in the shedRadRed06 is one of the sharper tools in the shedRadRed06 is one of the sharper tools in the shedRadRed06 is one of the sharper tools in the shedRadRed06 is one of the sharper tools in the shedRadRed06 is one of the sharper tools in the shedRadRed06 is one of the sharper tools in the shedRadRed06 is one of the sharper tools in the shedRadRed06 is one of the sharper tools in the shedRadRed06 is one of the sharper tools in the shed
RadRed06's Avatar
RadRed06's Tacoma Gallery
Originally Posted by Brunes View Post
You were given the wrong plugs....The first page of this thread has the proper part numbers...-01235 iirc...
fuuu... I told him 2006 and he still messed up
Old 06-28-2013, 03:39 PM   #1143
Always outnumbered, never outgunned
Agent Smith is one of the sharper tools in the shedAgent Smith is one of the sharper tools in the shedAgent Smith is one of the sharper tools in the shedAgent Smith is one of the sharper tools in the shedAgent Smith is one of the sharper tools in the shedAgent Smith is one of the sharper tools in the shedAgent Smith is one of the sharper tools in the shedAgent Smith is one of the sharper tools in the shedAgent Smith is one of the sharper tools in the shedAgent Smith is one of the sharper tools in the shedAgent Smith is one of the sharper tools in the shed
Agent Smith's Avatar
Agent Smith's Tacoma Gallery
You know, they fuck you at the drive thru!
Old 06-28-2013, 04:02 PM   #1144
CRIMAR30 is a name known to allCRIMAR30 is a name known to allCRIMAR30 is a name known to allCRIMAR30 is a name known to allCRIMAR30 is a name known to allCRIMAR30 is a name known to all
CRIMAR30's Avatar
CRIMAR30's Tacoma Gallery
SPARK PLUG CHANGE
Did mine yesterday, piece of cake!!
Old 07-14-2013, 09:52 AM   #1145
//TRD
GeauxTigers is on a distinguished road
GeauxTigers's Avatar
GeauxTigers's Tacoma Gallery
This write up worked for me. I changed my plugs out yesterday, using this as a guide. I have 64K on the truck and bought it used 2 years and 24k miles ago. Previous owner had not replaced the plugs. Anywho. Thanks Chris.
Old 07-14-2013, 01:02 PM   #1146
prclements is one of the sharper tools in the shedprclements is one of the sharper tools in the shedprclements is one of the sharper tools in the shedprclements is one of the sharper tools in the shedprclements is one of the sharper tools in the shedprclements is one of the sharper tools in the shedprclements is one of the sharper tools in the shedprclements is one of the sharper tools in the shedprclements is one of the sharper tools in the shedprclements is one of the sharper tools in the shedprclements is one of the sharper tools in the shed
prclements's Avatar
prclements's Tacoma Gallery
Send a message via AIM to prclements
Thanks chris4x4 for the post. Just used the info to change my plugs
Old 07-14-2013, 02:32 PM   #1147
Asian RedNeck
BenMara is a name known to allBenMara is a name known to allBenMara is a name known to allBenMara is a name known to allBenMara is a name known to allBenMara is a name known to all
BenMara's Avatar
BenMara's Tacoma Gallery
Send a message via AIM to BenMara
Denso 3381 K20HR-U11 same PN# for SCed V6?
thinking about goin 2 steps cooler Denso 5346 IKH24
Old 07-14-2013, 09:37 PM   #1148
hobiesan is on a distinguished road
hobiesan's Avatar
hobiesan's Tacoma Gallery
Changed my plugs out tonight for the first time. Should have done it at 30K, but I did it at 45K. The pic below shows what the old plugs looked like. They all had a brown/burnt looking ring around the top of the insulator just above the nut. Has anyone else seen this? Is it normal or does it indicate any problems?
Old 07-15-2013, 06:34 AM   #1149
Normal, mine were like that and other pics I've seen on this thread are the same.
Old 07-15-2013, 09:42 AM   #1150
hobiesan's Avatar
Thanks AgentSmith. Good to know it's normal.
Old 07-15-2013, 02:25 PM   #1151
Jonah is on a distinguished road
Jonah's Tacoma Gallery
Awesome write up Chris. I just changed my plugs for the first time and it took exactly 2 hours. The step-by-step instructions and pictures make it a piece of cake.
A couple of comments from my experience:
1. The 5/8" deep socket I used for the plugs didn't have a rubber bushing insert to hold the plugs for extraction from the well. I put a small rare earth neodymium magnet inside the socket and the plugs came right out.
2. Like a lot of people, I've always used a piece of rubber tubing to start the spark plugs into the hole to prevent cross-threading. This is always frustrating because the plug tends to flop around and it takes some fiddling to get it started. This time, I put a piece of stiff wire (#12 electrical wire) inside the tubing to keep it straight. It worked like a charm and the insertion process was quick and easy.
3. Keep on eye on the spring clamp from the vent hose. I left it on the hose and it was gone when I went to reinstall it. After a couple of anxious minutes, I found it sitting on the valve cover. I suggest taking it off the hose and setting it aside
Old 07-20-2013, 12:35 PM   #1152
BassMaster06 is a glorious beacon of lightBassMaster06 is a glorious beacon of lightBassMaster06 is a glorious beacon of lightBassMaster06 is a glorious beacon of lightBassMaster06 is a glorious beacon of lightBassMaster06 is a glorious beacon of light
BassMaster06's Avatar
BassMaster06's Tacoma Gallery
Thanks for the write-up Chris. I changed my plugs out this morning. Afterwards, I took your advice and drove to the beer store
Old 07-21-2013, 07:21 PM   #1153
Shanran71 has a spectacular aura aboutShanran71 has a spectacular aura about
Shanran71's Tacoma Gallery
40,0000 miles after reading this (and using the info) for my last plug change...it was useful again on todays plug change. Thanks
Old 07-22-2013, 11:24 AM   #1154
fadippides is on a distinguished road
fadippides's Tacoma Gallery
Thanks for the post, changed my plugs on my 2012 with 52K. Plugs looked decent, NGKs were at ~.053 gap densos were more like .043. Only difference with the 2012 is the air intake is a pain to get off because the 2nd bolt is hard to get to, I just moved it while working and left it on.
Old 07-23-2013, 06:49 PM   #1155
ST3VE is one of the sharper tools in the shedST3VE is one of the sharper tools in the shedST3VE is one of the sharper tools in the shedST3VE is one of the sharper tools in the shedST3VE is one of the sharper tools in the shedST3VE is one of the sharper tools in the shedST3VE is one of the sharper tools in the shedST3VE is one of the sharper tools in the shedST3VE is one of the sharper tools in the shedST3VE is one of the sharper tools in the shedST3VE is one of the sharper tools in the shed
ST3VE's Avatar
ST3VE's Tacoma Gallery
Followed these steps and it took about a hour and a half. Thanks Chris!
Old 07-27-2013, 09:52 PM   #1156
cleveland48 is on a distinguished road
cleveland48's Avatar
cleveland48's Tacoma Gallery
I have finally decided to do this myself tm morning instead of paying the dealer. I stopped by today and got 6 denso plugs. Does the old rule of always disconnect the battery when doing something like this still apply? Or is it not necessary? I havnt changed plugs since I had a 94 5.0 I always disconnected it then. But was never sure if u actually had to do that.
Old 07-27-2013, 10:43 PM   #1157
chris4x4 [OP] chris4x4 is offline
chris4x4's Avatar
chris4x4's Tacoma Gallery
You don't have to disconnect the battery.
Spark Plug Change BImike 2nd Gen. Tacomas 12 07-05-2014 07:47 AM
HOW TO: Change Your Spark Plugs and Wires (2.7 liter 3RZ-FE engine) trdracing5 1st Gen. Tacomas 27 02-23-2014 12:59 PM
How To - Change Spark Plug 1st Gen 95.5-04 2RZ-FE(2.4L)/3RZ-FE(2.7L) The Parts Whore Technical Chat 7 01-28-2012 12:58 PM
1GR-FE Oil on spark plug BlueT 2nd Gen. Tacomas 8 05-01-2011 05:39 PM
Need How-To: spark plug change on 2.7 (2TR-FE) DGXR Technical Chat 3 02-05-2010 08:05 PM
