LSC15's 95 Tacoma 4x4
Clunking when I start the truck
Old 01-14-2014, 12:13 PM   #1
chasebrooks14 will become famous soon enoughchasebrooks14 will become famous soon enough
chasebrooks14's Avatar
chasebrooks14's Tacoma Gallery
a few weeks back I replaced my brake booster and afterward when I went to start it up, and right before the engine catches, it makes this loud clunking noise. it sounds like I dropped a tool and its being slung around. im sure just replacing the starter will fix this but I just wanna see if its some other problem.
Old 01-14-2014, 12:25 PM   #2
Keep It Wild. KCCO
WildLand is one of the sharper tools in the shedWildLand is one of the sharper tools in the shedWildLand is one of the sharper tools in the shedWildLand is one of the sharper tools in the shedWildLand is one of the sharper tools in the shedWildLand is one of the sharper tools in the shedWildLand is one of the sharper tools in the shedWildLand is one of the sharper tools in the shedWildLand is one of the sharper tools in the shedWildLand is one of the sharper tools in the shedWildLand is one of the sharper tools in the shed
WildLand's Avatar
WildLand's Tacoma Gallery
Gah, mine does the same thing. When ever I accelerate there is a clunk noise. Ive read some things and here are some quotes I found:
"I noticed the transmission mount at the output of the trans is made to move up and down along a bolt shoulder. Upon further inspection, the entire rear trans mount is a rubber mount, and this thing binds when you stop. I cut 3 pieces of rubber in a 3" diameter "donut" shape, slit the sides of the donut and placed them around the shoulder bolt to reduce the travel space of the mount. No more clunk! Free fix. No mechanics telling me its "normal" either!"
"Also had this problem on a 2000 Tacoma Pre Runner TRD. Dealer said it was the rear locker, and was normal, but I also found that my drive shaft spline was not properly lubed, or low grade grease was used. Refilled with Lucas Red n Tacky #2 (high temp/high shear) and the problem was fixed."
and here is something my dad sent me http://www.yotatech.com/f2/tacoma-clunk-2627/
dont know if its the same thing but my clunk is coming from the rear
Old 01-14-2014, 12:33 PM   #3
your problem is axle wrap. Mine does the same thing. Its because the leaf springs are worn and old and the separate whenever accelerating, causing the axle to "wrap" upwards. then whenever you come to a stop, it "clunks" down. you can fix this with traction bars or a cheaper alternative is something like this. just get a Ubolt type clamp and tighten the shit out of it and bam! no more axle wrap!
Old 01-14-2014, 12:41 PM   #4
Keep It Wild. KCCO
WildLand's Avatar
Oh... well hell yeah! I thought it was something with the leafs...
Thanks for solving my problem and hope yours gets figure out too
Display Modes
07 Tacoma Odd clunking/popping sounding coming from under truck Johnnycage Performance and Tuning 27 03-08-2014 04:49 AM
Just needed a jump start, will my truck start back up tomorrow? drjohnson36 2nd Gen. Tacomas 13 09-14-2011 09:10 AM
start up truck? samsung 2nd Gen. Tacomas 10 05-02-2011 07:03 PM
New truck no start drucilla 2nd Gen. Tacomas 13 11-02-2009 06:27 PM
truck would not start Kennyu 2nd Gen. Tacomas 2 10-22-2008 10:50 AM
