'98 to '04 3RZ swap ?
Old 01-23-2014, 10:27 PM   #1
Dustrider [OP] Dustrider is offline
Dustrider is on a distinguished road
Dustrider's Tacoma Gallery
If I have 2 fully complete motors with all engine controls and mine is a 1998 3rz, the replacement might be a 2004 4runner 2.7 (assuming its a 3rz)
Does anyone know if I will be able to just swap out the valve covers and use the coil packs instead of the COP's ?
I assume the pointer for the pickup coil will be on all 3rz cams
if its a 4 port head, can I put my '98 throttle body and other engine control junk from my 8 port plenum onto a 4 port plenum ?
I assume my 5 spd bell housing will bolt up after removing the 2004 auto housing
Old 01-23-2014, 10:29 PM   #2
MGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shedMGMTacolover55 is one of the sharper tools in the shed
MGMTacolover55's Avatar
MGMTacolover55's Tacoma Gallery
You have to use the 2004 engine parts on the engine.
Old 01-24-2014, 12:10 PM   #3
ASE Master Tech
BamaToy1997's Avatar
BamaToy1997's Tacoma Gallery
Changing from the 8 port to a 4 port will affect engine performance. You don't want to mix that. While the base engine is 2.7L, there are several mechanical and electronic changes that can cause problems with doing a swap over that many years.
CS144 Alternator Swap into 3rz wolfgang123 1st Gen. Tacomas 7 09-05-2014 12:57 PM
'98 to '04 3RZ swap ? Dustrider 4 Cylinder 2 01-26-2014 05:20 PM
98 to 01-04 front bumper swap? ARkansasTAco521 1st Gen. Tacomas 12 01-29-2013 11:50 AM
84 toyota 3rz swap quailhound Toyota Trucks & SUVs 4 05-21-2012 11:28 AM
Swap 2RZ for 3RZ? sgtlethargic 4 Cylinder 1 01-10-2012 08:29 PM
