Cam shaft seal replacement debate.
Old 04-25-2014, 11:37 AM   #1
Gooiegoogoo is on a distinguished road
Gooiegoogoo's Avatar
Gooiegoogoo's Tacoma Gallery
Should I replace them at 95k on 2003? Did you do it yourself?
It would seem foolish not too, but i am afraid it is not as easy as it sounds.
Also not entirely convinced i should need too, as long as its not leaking.
Old 04-25-2014, 07:37 PM   #2
ASE Master Tech
BamaToy1997's Avatar
BamaToy1997's Tacoma Gallery
If they are not leaking, then there really is not much of a reason to replace them. However there is also the school of thought that if you are already replacing the timing belt and water pump, you may as well replace the cam and crank seals in front as well.
DIY: How To Replace An Output Shaft Seal NorCalTRD 2nd Gen. Tacomas 25 05-11-2014 08:47 AM
Question about Transmission Output Shaft Seal flyboy718 Technical Chat 0 01-25-2014 02:51 PM
Steering Shaft Fire wall Bushing/ Gusset/ Seal???? WTF Just a ?? IgnorantlyAlberta Technical Chat 9 01-12-2013 10:31 PM
Replacing cam and crankshaft oil seal on a 2001 3.4 tacoma Poppawheelie 1st Gen. Tacomas 1 07-03-2012 05:02 PM
Cam an Crank Seal Replacements. T-Belt is off. B-Field 1st Gen. Tacomas 3 06-22-2010 11:04 AM
