A/C doesn't work....then does.
Old 05-08-2014, 05:04 PM   #1
BlackBuzzard is on a distinguished road
BlackBuzzard's Tacoma Gallery
2008 V6 double cab TRD:
Air does not blow cold going down highway today (80F) no matter what fan speed or defrost......so I give up and roll down window.
Later same day in parking lot, I try it again and it almost instantly blows nice and cold, and still works find in driveway tonight.
Any thoughts as to why AC just would not come on?
Any history out there of some electrical issue that may cause its intermittent function?
All feedback appreciated.
BB
Old 05-08-2014, 05:56 PM   #2
41 Year Toyota/Chrysler Tech/ASE Master
Tacoma Mike is one of the sharper tools in the shedTacoma Mike is one of the sharper tools in the shedTacoma Mike is one of the sharper tools in the shedTacoma Mike is one of the sharper tools in the shedTacoma Mike is one of the sharper tools in the shedTacoma Mike is one of the sharper tools in the shedTacoma Mike is one of the sharper tools in the shedTacoma Mike is one of the sharper tools in the shedTacoma Mike is one of the sharper tools in the shedTacoma Mike is one of the sharper tools in the shedTacoma Mike is one of the sharper tools in the shed
Tacoma Mike's Avatar
Tacoma Mike's Tacoma Gallery
BB
When the ac does not work, does the ac light blink?
Also, when it blows hot you need to open the hood and see if the ac compressor is turning. Not the pulley, the very end of the unit is turning also.
Old 05-08-2014, 06:11 PM   #3
Light did not blink in cab...it stayed on when blowing hot. And it stayed on when when it blew cold later on when problem disappeared.
Have not checked to see if compressor engages when it blows hot as the problem has vanished for the moment.
But, obviously, in the driveway when it blows cold the cab light comes on and I hear the compressor come on. And hear it switch off when I switch it off in cab.
Its intermittent which makes me want to start checking wire harness connectors etc.
BB
Old 05-08-2014, 06:21 PM   #4
BB
You need to check the condition of the ac compressor while blowing warm and get back to us.
Old 02-02-2015, 06:31 PM   #5
B R B R is offline
B R is a glorious beacon of lightB R is a glorious beacon of lightB R is a glorious beacon of lightB R is a glorious beacon of lightB R is a glorious beacon of light
B R's Tacoma Gallery
Same problem happened to me today, very strange. I've never had the air not work properly until today. I was on the freeway, decided to turn air on, but it just kept blowing warm air, no matter what I did to the controls (well it did blow hot when I cranked the temp over to that end). I gave up, drove about 30 mins later (without having shut down) pushed the a/c button on again & then it started working again fine. Go figure.
Now I'll be paranoid about it not working again on a random basis. I don't think it's as simple as a wonky switch, because I was messing with all of them a lot when the problem first happened.
Old 02-03-2015, 06:28 AM   #6
Lurkin is one of the sharper tools in the shedLurkin is one of the sharper tools in the shedLurkin is one of the sharper tools in the shedLurkin is one of the sharper tools in the shedLurkin is one of the sharper tools in the shedLurkin is one of the sharper tools in the shedLurkin is one of the sharper tools in the shedLurkin is one of the sharper tools in the shedLurkin is one of the sharper tools in the shedLurkin is one of the sharper tools in the shedLurkin is one of the sharper tools in the shed
Lurkin's Tacoma Gallery
If you haven't used the AC in a while, cold climate or somesuch, it may just take a cycle or two to get the system and seals doing what they need to do. I would also check the freon pressures to ensure you have adequate charge.
A/C Doesn't Work s810 2nd Gen. Tacomas 11 08-08-2012 08:32 PM
Defroster doesn't work rusty55125 Technical Chat 0 07-20-2011 08:11 AM
Doesn't anyone work?? georgeandkanoa Off-Topic Discussion 33 05-24-2011 12:44 PM
Horn doesn't work Bdiddy11 1st Gen. Tacomas 25 09-22-2010 01:33 PM
A/C doesn't work... tmantstud 1st Gen. Tacomas 0 07-08-2008 12:48 PM
