Power steering problem !
Old 06-26-2014, 08:30 AM   #1
bultacomatador is on a distinguished road
bultacomatador's Tacoma Gallery
I have a 2008 4x4 extended cab 4 cyl. Tacoma: Has anyone had any power steering problems... mine seems to cut off and makes it difficult to steer...Not sure if its the pump or what..!!! any info would be a great help..
Thanks Tom
Old 06-26-2014, 11:35 AM   #2
tan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shedtan4x4 is one of the sharper tools in the shed
tan4x4's Avatar
tan4x4's Tacoma Gallery
Fluid level could be low, check and top it off with Dexron-type ATF (NOT ps fluid !)
Also, could be loose PS belt (should also cause a squealing sound)
Old 06-27-2014, 11:13 PM   #3
DK2006Yota is one of the sharper tools in the shedDK2006Yota is one of the sharper tools in the shedDK2006Yota is one of the sharper tools in the shedDK2006Yota is one of the sharper tools in the shedDK2006Yota is one of the sharper tools in the shedDK2006Yota is one of the sharper tools in the shedDK2006Yota is one of the sharper tools in the shedDK2006Yota is one of the sharper tools in the shedDK2006Yota is one of the sharper tools in the shedDK2006Yota is one of the sharper tools in the shedDK2006Yota is one of the sharper tools in the shed
DK2006Yota's Tacoma Gallery
2005+s use 1 serpentine belt (not 3 belts like 1st gens) and are auto tensioned. So theres no belts to tighten unless your auto tensioner is not doing its job.
I'd agree, check your fluid level first. Otherwise it sounds like your PS pump is going out.
Old 06-28-2014, 02:02 AM   #4
Old & Forgetful
Janster's Avatar
Gender: Female
Janster's Tacoma Gallery
If you're low on fluid, then you've probably got air in the lines.
You need to jack up the front end of the truck, pour fluid in the resevoir and bleed the system.
Bleeding the system is easy. Front wheels off ground. Truck on. Turn wheels slowly from lock to lock several times while keeping the reservoir FULL. The air bubbles will come out of the reservoir from the return line. The key is keeping the reservoir full so it doesn't suck air in. Keep turning from lock to lock until no more bubbles appear in the reservoir.
Power steering problem Jamie w New Members 4 02-27-2013 09:57 AM
power steering problem fitryders2 Technical Chat 6 03-09-2011 07:19 PM
Power steering/cv boot problem dylandercole 1st Gen. Tacomas 3 02-16-2011 08:10 AM
power steering problem newbtaco 1st Gen. Tacomas 9 09-21-2010 01:23 PM
Power Steering Problem Blacktaco05 Technical Chat 2 07-02-2010 05:44 PM
