Compressor problem?
Old 09-15-2014, 04:11 PM   #1
steve390 [OP] steve390 is offline
steve390 is on a distinguished road
Army:
steve390's Tacoma Gallery
Compressor problem?
I overcharged my ac system a few months ago because I thought it was low since it was blowing only barely cool air. Got the pressure back to where it should be. But now in idle the compressor cycles off and on constantly a lot of the time and won't blow cool air unless the truck is moving. Also, now the blower ceases to turn on unless its on high. Getting the feeling that a new compressor will be in my future. Checked the fuses and they are good.
Old 09-15-2014, 08:54 PM   #2
G17GUY is a splendid one to beholdG17GUY is a splendid one to beholdG17GUY is a splendid one to beholdG17GUY is a splendid one to beholdG17GUY is a splendid one to beholdG17GUY is a splendid one to beholdG17GUY is a splendid one to behold
G17GUY's Tacoma Gallery
Start over. Pull a vacuum, put 22oz of 134a and see if that works. If not you have other issues.
Old 09-20-2014, 09:27 AM   #3
Did you try this yet?
Old 09-21-2014, 12:24 PM   #4
"... Intercepting The Localizer"
File IFR is one of the sharper tools in the shedFile IFR is one of the sharper tools in the shedFile IFR is one of the sharper tools in the shedFile IFR is one of the sharper tools in the shedFile IFR is one of the sharper tools in the shedFile IFR is one of the sharper tools in the shedFile IFR is one of the sharper tools in the shedFile IFR is one of the sharper tools in the shedFile IFR is one of the sharper tools in the shedFile IFR is one of the sharper tools in the shedFile IFR is one of the sharper tools in the shed
File IFR's Avatar
File IFR's Tacoma Gallery
That is unrelated to your compressor problem. You have a bad blower motor resistor.... That is an easy 15/20 minute fix to change out.
Timing chain problem Valve problem ticking noise from engine maza mike 1st Gen. Tacomas 0 03-24-2013 06:57 PM
ARB Compressor problem acidfly 1st Gen. Tacomas 3 12-31-2012 11:51 AM
Electrical problem, ECM or DLC problem akp357 Technical Chat 0 02-04-2010 04:14 PM
compressor oil problem/question tacomaman06 Garage / Workshop 1 01-21-2010 04:38 AM
Hey guys, new member with an oil tank problem and motor problem hnrajah 1st Gen. Tacomas 5 12-17-2009 03:55 PM
