Motor Mount Sag
Discussion in 'Technical Chat' started by 1fortheroad, Dec 15, 2014.
  1. Dec 15, 2014 at 1:04 PM
    1fortheroad
    1fortheroad [OP] Member
    Bill
    So Cal
    06 4-Door 6' Bed
    OK, 2006, 4 dr. V6
    There is a vibration which to me is coming from the dash. I took it to a shop and was told that the air intake box was vibrating and that the motor mounts were "sagging" which allows the vibration to be carried to the cab. Anyone ever hear of this?
  2. Dec 15, 2014 at 6:39 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Don't know anything about sagging motor mounts,, if your air intake is vibrating it's where the box goes into the pass. fender.
    Take out the two bolts that hold it to the inner fender and undo the hose clamp to remove the box.
    Once that's done you'll be able to see the cheap foam gasket that is around the air horn, which is what goes bad allowing the plastic horn to vibrate on the fender.
    What I did was put new foam tape around the air horn and that cured my noise.
  3. Dec 16, 2014 at 8:45 PM
    1fortheroad
    Bill
    So Cal
    06 4-Door 6' Bed
    Thanks Sparkystaco.
  4. Dec 17, 2014 at 11:15 AM
    sparkystaco
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    Hope that cured you vibes, let us know.
  5. Mar 23, 2015 at 12:07 PM
    1fortheroad
    Bill
    So Cal
    06 4-Door 6' Bed
    Sorry it has taken me so long to reply. Tried to see if Toyota had posted a service bulletin on this subject. Anyway, a little foam tape and the noise is gone. Now I'm annoyed at the shop that wanted to change the motor mounts.
    Thanks!
    Bill
