| Register | Search For Products | Site Information | Glossary | Calendar | Search | Today's Posts | Mark Forums Read |
#1 |
Hello,
I have a 2004 regular cab, 4 cylinder Tacoma. All of a sudden, I am unable to fill the fuel tank like I used to. When filling, the tank acts like it is full or obstructed. I have to pull the fuel nozzle way out and trickle the gas in or the fuel will back up in the neck and shut off the nozzle. It can take 15 minutes or more to fill from empty. Does anyone know what the cause of this could be?
#2 |
The one you are not!
Nothing I can think of off the top of my head. Get some friends or family and pull the bed off and remove the filler hose and see what is causing it.
#3 |
I always thought that the sensor was in the hand pump not the filler hose. But I could be wrong about that.
#4 |
Is it possible there is a check valve or anti-syphon valve at the inlet to the fuel tank?
I guess I will have to bite the bullet and take the truck back to the dealership. |
#5 | |
Do you stick the nozzle all the way in? if only half way and you squeeze the trigger full, it'll back flow right back in the nozzle tripping it as full.. When it's empty and you unscrew the gas cap do you here air escaping? gas tank should be pressurized.. Do you have a CEL/MIL ?
__________________
Get your facts first, and then you can distort them as much as you please Mark Twain 11/30/1835 - 04/21/1910 US author |
#6 |
It happens all the time. I have tried sticking the nozzle all the way in, as far out as possible and everywhere in between. I haven't noticed air escaping when I remove the gas cap, but I don't know that for sure. I've owned the truck about 6 months and I could fuel it like any other vehicle prior to this problem.
One day I tried to fuel up and the pump kept shutting off. I blamed the pump and went to another service station, but I had the same result at the next station. I've never seen anything like it. I was hoping to fix it myself, but I have no idea what is wrong so I am going to take it back to the dealership. Of course, this happed when I was 700 miles over 36,000. What is a CEL/MIL? |
#7 |
CEL = check engine light
#8 | ||
__________________
#9 | |
Member Dismemberer
Just ran into this thread now. Too bad you are MIA. You should visit often dude and so should I. It appears you are having a venting problem such as a blocked or kinked vent tube When you are filling an empty or partially empty vessel, the air occupying the empty portion of the vessel must be evacuated simultaneously or allowed to escape in order for another liquid to occupy the space the air was already occupying. It appears your tank is not venting properly and the air displacement is occurring deep down through your filler port, which is obstructed by the gas nozzle and the new gasoline entering the tank. The vent nozzle, if I remember this right terminates in and around the gas filler port. Your vent pipes along with excess fuel return should be all clumped together around the sending unit on top of the tank. This is assuming your fuel pump is in the tank. You’ll have to drop the tank and follow the tubes to trouble shoot. If your truck was off roaded and sank in the mud, I would suspect one of the above conditions. Look for any obstruction of a small port around the filler port before you drop the tank since dropping the tank is a pain-in-the-neck kind of job. The vent pipe may even terminate about 2 to 3 inches inside the filler port. It just occured to me, the vent pipe has to terminate within and NOT outside the gas tank containment system or you'll smell fumes all the time and your gas would evaporate causing a safety hazard. It should terminate above the trap door which the gas nozzle pushes down upon entry. If you try to look at the filler port from underneath the truck, you will probably see the vent tube's exit point. See where it terminates and clear the obstructions, if any. Let us know what happens. Good luck.
__________________
"My honour is more valuable than my commission". ![]()
#10 |
Any update? I need help - takes me 30 minutes plus to fuel
I have a 05 Tacoma and have the same exact fueling issue. I am so needing help. The check engine light is on and the codes are for the the speedometer and the thermostat, both which appear to be working fine. Anyone have any insight?
#11 |
Moderator; TW Moderator
What do the codes say exactly?
__________________
If you have a question, ask... Don't spread rumors without knowing the facts.
My responsibility on this forum is to the members and the integrity of this forum. |
#12 |
My slow fueling problem was an obstruction in the tank. Apparently, someone put a sticky tape substance like a packaging tape into my filler neck and it gummed up the works. The dealership cleaned it all out and $180 bucks later I was good to go again.
#13 |
tacoma problem is the expose fuel tank..
anyone can open it and put anything in or out of it.. they should have the push button to open the fuel door!! |
#14 |
Carolina Alliance: LAZY DIVISION
Another thing that can cause this problem is if you over fill your tank to much you will have liquid fuel go into the evap system and glog up you evap charcoal canister. the canister is only designed foe fuel vapor not liquids if it gets to soaked the escaping fumes from you empty tank have no place to go and your pump will keep shuting off.
| Display Modes | |
| 60 miles on the lower quater tank? | sslongmuir | Performance and Tuning | 1 | 10-01-2007 04:05 PM |
| 19.3 MPG for first tank. | smckeown | 2nd Gen. Tacomas | 47 | 09-29-2007 11:48 PM |
| Tune up on a 2004 | CutnShootTaco | Performance and Tuning | 3 | 09-04-2007 11:24 PM |
| 2004 Tacoma 2wd to 4wd?? Is it possible? | Norcaliboy22 | Technical Chat | 10 | 02-14-2007 01:57 PM |
| 2004 Tacoma TRD | MARKIE | New Members | 1 | 01-10-2007 08:17 AM |
