Will it hold up?
Discussion in 'Technical Chat' started by RelentlessFab, Sep 21, 2009.
  1. Sep 21, 2009 at 9:32 PM
    RelentlessFab
    RelentlessFab [OP] Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    Over the last week or so i've noticed an occasional strange noise from my rear end. Heard it mainly when navigating parking lots at low speed. Well now over the last 2 days it has started to get worse to the point where today it appears there is something severely wrong with it. I pulled it into our garage tonight and threw the jack under the rear end, then rotated the tires by hand while my dad listened from a creeper under the truck. When holding one of the rear tires(usually the drivers) and rotating the other, it would rotate fairly freely, then begin to bind, make a growling and release with a chatter/clatter(audible from 20 ft from the truck!) coming from the 3rd member. I would imagine this has something to do with the LSD in the rear end?
    My friends dad(who is a Jetboat mechanic) said that their CR-V has a LSD and began to do the same thing a while back. The owner of a local car repair shop advised him to change out the oil/LSD additive in the rear end and afterward it totally solved the symptoms they were experiencing. Tomorrow im going to change out the oil/LSD additive and hopefully it helps because on wednesday morning im going to be leaving to go back to college which is a 250 mile drive and i'll be loaded with quad, tools, clothes, etc.
  2. Sep 21, 2009 at 9:49 PM
    RelentlessFab
    Eric
    Sparks, NV
    Hey, CHRIS!?!?!? :D :D
  3. Sep 21, 2009 at 10:00 PM
    senor taco
    senor taco ROLLIN ON RUST
    Steve
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Good luck
  4. Sep 21, 2009 at 10:10 PM
    RelentlessFab
    Eric
    Sparks, NV
    Thanks.
    Oh, and just to add a little more info: My truck has about 33,700 miles currently, and the rear diff oil was changed out for full synthetic and LSD additive at about 18000 miles.
  5. Sep 21, 2009 at 10:39 PM
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    damn dude this sounds bad, i had my bearings go out and it growled really bad so i dunno if you could check those or not
  6. Sep 21, 2009 at 10:42 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    Maybe you shouldn't have gone synthetic.
    My dif fluid didn't get changed until the recommended interval of 120,000.
  7. Sep 21, 2009 at 10:56 PM
    RelentlessFab
    Eric
    Sparks, NV
    Yeah, i dont know. Maybe not. But I've always heard that synthetics help gas mileage, especially when its cold, and I get some pretty long and cold winters. I also tow a LOT so thats why I changed it when i did too.
    I pulled the filler plug and checked the oil earlier and it seemed perfect still. just a very slight gray/tan hint to it so it almost appears new still. Thats why I cant believe that the oil is whats causing any of these issue. :(
  8. Sep 21, 2009 at 11:04 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    hey i just put synthetic in mine today so if it starts growling at me ill let yu know haha. it's gonna get the 300 miles test on wednesday
  9. Sep 21, 2009 at 11:26 PM
    RelentlessFab
    Eric
    Sparks, NV
    Well, i work my truck pretty good, but I definately don't beat on it and abuse it. I take care of it and respect it. After all, i need it to be able to make my money, so the last thing I want is breakage and down time. I agree though, this is a great excuse to install an ARB in it finally! :D Im going to see what the Toyota dealer says on wednesday or thursday though because whatever the problem is, it should still be covered under warranty.
  10. Sep 21, 2009 at 11:42 PM
    genxer36
    Sean
    Bethlehem,GA
    I know syn shouldn't hurt it. But I was thinking in terms of my lower unit on my boat(yes I know not the same as the truck rear dif). The repair manual & Mercury says absolutely do not put syn in, if it did not come with syn. That was kinda strange. Why would it matter?
  11. Sep 22, 2009 at 5:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I had that happen to my truck when I switched to FS gear oil in the rear diff. Use a good Dyno oil, with 4 to 8 ozes of the GM LS addative. :)
  12. Sep 22, 2009 at 8:22 AM
    RelentlessFab
    Eric
    Sparks, NV
    Thanks Chris, will do. I'm gonna go drain it to see what it looks like(make sure theres no metal) and then run to town in my dads car to get the oil. :crossesfingers:
  13. Sep 22, 2009 at 8:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  14. Sep 22, 2009 at 9:42 AM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
  15. Sep 22, 2009 at 11:50 AM
    RelentlessFab
    Eric
    Sparks, NV
    Well, changed it out with this stuff:
    Seems to be a little better now after driving it about 10 miles on some curvy roads by my house. Still got it to chatter once at low speed, and then once back home I pulled it in the garage, jacked it up and did the trick with the rear tires. I can get it to chatter, but once again it does seem a bit better. Hopefully it just takes a little time to wear in to the clutches in the LSD and then goes away entirely. My rear diff seems to be getting pretty warm though. At about 70* outside it got quite warm just from the 10 mile drive I did, I can still hold my hands on it, but it was pretty warm. This all seem normal?
  16. Sep 22, 2009 at 12:30 PM
    RWS_350MAG
    RWS_350MAG Well-Known Member
    Don
    Wisconsin
    2010 TRD Off Road 4x4 AC
    Toytec Ultimate lift, Tailgate anti-theft mod, 265/75-16 Goodyear Duratrac tires on stock rims, Lakeland Predator Cap, Rear seat headrests removed, Husky Floorliners
    The differential housing will get warm, but it shouldn't be hot. My guess is that you have a bearing going bad. It happened to me in my Jeep. I noticed a growling noise, and the differential housing was very warm. I popped the cover off the rear end, and the oil looked like it had glitter in it. I removed the differential from the housing, and the bearing on the drivers side was scored.
