Changing out coil packs for a distributor
Old 09-23-2009, 07:13 AM   #1
Maxola89 [OP] Maxola89 is offline
Maxola89 is on a distinguished road
Maxola89's Tacoma Gallery
i just swap my 2.7 for a 2.4 everything fit perfect except for the individual coil pack that go on the spark plugs, the coil packs came off the 2.7. The 2.4 came with plug wires and i was hoping the coil packs would fit the 2.4 but they didnt. So what should i do or should i install a distributor with the plug wire.
p.s. the coil pack were connected right off the wireharness so i have no plug ins for a distributor.
HELP me out pls.....
Old 09-23-2009, 07:16 AM   #2
chris4x4's Avatar
chris4x4's Tacoma Gallery
Welcome to TW.
Only thing I can think of is swapping the ECU from a 2.4. You need the right ignition for the engine.
Old 09-23-2009, 07:21 AM   #3
i knew i might have to swap the ecu but how about after, what do i o about the ditributor?
Old 09-23-2009, 07:22 AM   #4
chris4x4's Avatar
Im not sure... I may not be awake enough yet to be able to give a viable solution, Ask 98tacoma27 (ben), and see what he says.
Old 09-23-2009, 07:29 AM   #5
:POOPCORN:
98tacoma27's Avatar
Marines:
98tacoma27's Tacoma Gallery
What year did the 2.4 come out of?
Old 09-23-2009, 07:30 AM   #6
would the individual coil packs work if i replace the ecu with a 2.4 one?
Old 09-23-2009, 07:31 AM   #7
i had a 2000 2.7 and i replaced it with 2000 2.4
Old 09-23-2009, 07:36 AM   #8
:POOPCORN:
98tacoma27's Avatar
Marines:
I am just making sure I have all the info before I give you a definitive answer.
From what you said above, the 2.4 has a distributor on it?
Old 09-23-2009, 07:38 AM   #9
chris4x4's Avatar
See thats screwing me up....I thought they were all coil for the 2000 year? My 2.7 was.
Old 09-23-2009, 07:54 AM   #10
:POOPCORN:
98tacoma27's Avatar
Marines:
As far as I know they were. There was a difference though. Some had two coils, one for two cylinders. They still utilized plug wires. The coil packs were on the front left of the motor. You can see about/aboot where they are on this picture.
Old 09-23-2009, 07:55 AM   #11
:POOPCORN:
98tacoma27's Avatar
Marines:
Here is another view. This is a 98 2.7 BTW
Old 09-23-2009, 08:23 AM   #12
:POOPCORN:
98tacoma27's Avatar
Marines:
Yea, you should have two of these somewhere on the left front of the motor.
Old 09-23-2009, 09:22 AM   #13
ben, the 2.4 came with those on the left front motor but i have no plug in from my wire harness to plug them in i can up load some pics to show you wat i mean if you want
Old 09-23-2009, 09:25 AM   #14
:POOPCORN:
98tacoma27's Avatar
Marines:
Pics are always helpfull. Do you have the hareness from the 2.4 also?
And those would be where the plugs attach to.
Old 09-23-2009, 09:28 AM   #15
yes but it was cut right before it goes in the dash brb
Old 09-23-2009, 10:15 AM   #16
ok theres a few i put up
Old 09-23-2009, 10:20 AM   #17
:POOPCORN:
98tacoma27's Avatar
Marines:
Also, Which of these stickers do you have? It should be located in the engine compartment close to the radiator or in the drivers side door jamb. I can't remember which.
Old 09-23-2009, 10:38 AM   #18
here it is
Old 09-23-2009, 11:52 AM   #19
:POOPCORN:
98tacoma27's Avatar
Marines:
Cali emmissions. Ok. I will have a definite answer for you in a few. Just need to verify a few things.
Old 09-23-2009, 01:39 PM   #20
:POOPCORN:
98tacoma27's Avatar
Marines:
Ok, here is what I have found both good and bad news.
Bad- The ECU's for the Cali emissions are different from the FED emission ECU's. The easy way to tell is the coil packs. One coil pack per plug indicates a Cali emissions (like your 3rz). The FED emissions have one coil pack per two spark plugs (like your 2rz).
Good- The Cali ECU for the 3rz and 2rz seem to be interchangeable. But there is one exception. The 3rz ECU monitors the EGR temperature where as the 2rz ECU DOES NOT. This wil not matter as long as you used the 3rz EGR vavle.
So what does this mean to you?
I think you have an easy fix here.
You can purchase the the individual coil packs for the 2rz. They will look similar to the 3rz. Install them and it should work with the exsisting 3rz harness.
The pinouts of the Cali ECU's and the color codes of the wiring match. The difference between the 2rz and 3rz mechanically is the compression ratio.
distributor coil pack questions... B.C.Burnette08 2nd Gen. Tacomas 2 02-02-2012 03:33 PM
How to check the coil packs on my 2000 2.7L 3RZFE engine? cvriv.charles 1st Gen. Tacomas 7 04-24-2011 06:44 PM
2000 2.4 liter coil packs and check engine light Toby21 4 Cylinder 0 10-24-2010 12:58 PM
Coil Packs Wont Fit On Top Of Spark Plugs Maxola89 Technical Chat 10 09-29-2009 03:17 PM
3.4 coil packs, rear O2 sensor, water temp sensor glassdoc Buy / Sell / Trade 6 01-28-2009 07:51 AM
