#1 |
Oxygen Sensor Problems
I got this trouble code on a 01 Tacoma with the 3.4 and 5 speed the code is for the 02 sensor on bank 1 sensor 1. I changed the sensor before the converter with a Denso exact fit 02 sensor. I used a scanner to clear the code and it was fine for a weeks. Then check engine light came back on for the same bank one sensor 1 O2 sensor. Why would this code keep coming back? I did check the wires and they are okay. The truck has 88,000 miles on it.
#2 |
bite me
Sometimes it may not be the O2 sensor. Are you running a K&N air filter or other oiled media type filter?
#3 |
No the truck is all stock. So you think i should try to clean the MAF sensor.
#4 |
I just cleaned the MAF it was pretty dirty thanks for the suggestion i can see that being a problem.
#5 |
bite me
Is the CEL still there? If so, just undo the negative battery terminal for a couple minutes and that should reset it. If the CEL comes back then you have other problems.
#6 |
bite me
BTW, how did you clean your MAF? Did you use an MAF cleaner? Hope you didn't use a Q-Tip to clean the wires, those things are very fragile and could be a costly mistake if you mess them up.
#7 | |
They should be here any day now!!!
Check for an exhaust leak also.
__________________
^^PLEASE DONATE^^
#8 |
The Green Machine
is that a p0168? i think thats what it is... i have that also.. says o2 sensor but it might be the cat.
| Thread Tools | Search this Thread |
| Display Modes | |
| Related / Mentioned Products |
| Front Diff problems, Steering shaft problems. No help from toyota | john01374 | 1st Gen. Tacomas | 7 | 03-10-2010 10:29 AM |
| 02 sensor? | zeski25 | 1st Gen. Tacomas | 7 | 08-12-2009 04:38 AM |
| need 02 sensor | HerNameIsLucy | Buy / Sell / Trade | 0 | 02-19-2009 03:59 AM |
| Can't get 02 sensors out? | k2pow | Performance and Tuning | 6 | 05-23-2008 06:49 AM |
| Just got an '02 | kscott | New Members | 7 | 03-07-2008 08:48 PM |
