Vibrations shaking the whole truck
Discussion in 'Technical Chat' started by SwampThing07, Dec 13, 2009.
  1. Dec 14, 2009 at 5:32 PM
    #21
    98tacoma27
    Ben
    Not Beech Creek
    Put it this way, you have an 07. There are guys here with older trucks running the same tires with never having to change a u-joint. A u-joint shouldn't go out on an o7 regardless.
    How long have you had the lift?
  2. Dec 14, 2009 at 6:05 PM
    #22
    SwampThing07
    SwampThing07 [OP] Well-Known Member
    Orlando, Fl
    07 prerunner/ Toytec lift/ 285 nittos/ MM 951
    885/ w 5100's, Grillcraft, HIDs, 285 nittos, MM 951B, Flowmaster duals, blackout tailights, tint, Sirius.
    bout 2 yrs
  3. Dec 15, 2009 at 12:13 AM
    #23
    tiger955
    tiger955 Well-Known Member
    Carson City
    06 Access 4WD
    trd suspension
    If they say it is a u-joint and say the lift is causing extra strain and won't warranty, take it home and change the joint yourself. If it just started suddenly after mudding I would say it is not likely, unless you broke one which would be obvious.
    If the truck is under warranty I would take it to them to check it out, and don't worry about admitting you were off road (these trucks are made for that). If they find damage warranty won't cover you have the option of paying them to fix it, or doing it yourself, or take it somewhere else. Depending on what the problem is, it may be doing more damage to keep driving it the way it is.
  4. Dec 15, 2009 at 4:05 PM
    #24
    SwampThing07
    Orlando, Fl
    OK update;
    Took it in toyota and thank you for TSBs. It ended up being a transmission mount gone bad, but appearantly there is a TSB from toyota for this. So who knows if i actually caused it. Anyways im very excited i don't have to shell out any money that i don't have! And for you guys having this problem take your truck in and see if its the mounts.
  5. Dec 15, 2009 at 4:08 PM
    #25
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I am aware of the TSB but it specifically states that it's for vibration between 15mph and 25mph.
  6. Dec 15, 2009 at 4:10 PM
    #26
    SwampThing07
    Orlando, Fl
    huh. i dk but they said its def. what it is. And after they told me that i can feel thats where the vibrations are coming from.
  7. Dec 18, 2009 at 3:00 PM
    #27
    SwampThing07
    Orlando, Fl
    So they did the tsb today and it fixed most of it, but its still does it a little every once in awhile. Toyota says they don't know what it is but everything is checking out okay. So they started a case with the toyota service bulletin to see if they can find anything out. They did say it was okay for me to drive it to GA for the holidays. So i guess i will wait and see what they say, he did however mention it could be a krink in the driveshaft, but it would be covered under warranty.
  8. Dec 21, 2009 at 3:10 PM
    #28
    SwampThing07
    Orlando, Fl
    Took it back in today, they told me my driveshaft was bad. They said the lift caused it to go bad. I argued with them that there are thousands of tacomas lifted without the driveshaft going bad. He then replied "well, ive never had this problem on a non-lifted tacoma." Either way they said they would cover it under warranty this one time and not if it happens again. Oh well im thankful they are doing this for me.
  9. Dec 21, 2009 at 3:11 PM
    #29
    98tacoma27
    Ben
    Not Beech Creek
    He is full of shit
  10. Dec 21, 2009 at 3:17 PM
    #30
    SwampThing07
    Orlando, Fl
    yep, but oh well. Im pretty sure it is bad, but not because of the lift.
  11. Dec 21, 2009 at 3:18 PM
    #31
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2018 4Runner LE
    TRD Pro Wheels BFG AT Tires
    atleast they are changing it .... i had vibrations also but it was my bearings ...
  12. Dec 21, 2009 at 3:23 PM
    #32
    SwampThing07
    Orlando, Fl
    yeh i was really worried they werent going too.
