99 Tacoma prerunner transmission question?
Old 05-14-2008, 09:58 AM   #1
Getsch [OP] Getsch is offline
Getsch is on a distinguished road
Army:
Getsch's Tacoma Gallery
I recently got a 99 tacoma prerunner xtra cab 2.7 and it has a small bug that seems to be in the transmission and I am wondering of anyone can help me diagnose it. When sitting in drive at a stop the transmission seems to keep in gear so that the engine seems to be fighting the brakes, but if you let of the brakes slowly and role an inch and stop again it will unload and be fine.
Any help?
Old 05-14-2008, 10:04 AM   #2
My hair is all natural
lsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shedlsocoee is one of the sharper tools in the shed
lsocoee's Avatar
lsocoee's Tacoma Gallery
There is an issue with the 05+ where there is a clunk when coming to a stop. It has something to do with the grease and the drive shaft connection. You might be having a similar problem. I'm sure someone here knows the actual problem I'm speaking of.
Old 05-14-2008, 10:25 AM   #3
Ridgerunner is one of the sharper tools in the shedRidgerunner is one of the sharper tools in the shedRidgerunner is one of the sharper tools in the shedRidgerunner is one of the sharper tools in the shedRidgerunner is one of the sharper tools in the shedRidgerunner is one of the sharper tools in the shedRidgerunner is one of the sharper tools in the shedRidgerunner is one of the sharper tools in the shedRidgerunner is one of the sharper tools in the shedRidgerunner is one of the sharper tools in the shedRidgerunner is one of the sharper tools in the shed
Ridgerunner's Avatar
Ridgerunner's Tacoma Gallery
"Chris 4x4" says:The leaf springs on the Tacomas are on the soft side of the spectrum. That being said ( please follow me on this) When power is applied to the tires, the torque moves your rear axel up a little bit causing the springs to twist like an "S" just not as dramatic. When you are at crusing speed the springs relax into their normal state. Now, when comming to a stop ( with an auto and below about 15 m.p.h. ) your engine is still trying to turn the tires and the differential is moveing up a little bit twisting the springs. When you are stopped and let off the brakes or ease off them, the springs unload and you hear the "thump". A small amount a axel wrap is not a bad thing and is normal on most Tacomas. It can be tammed with the addition of an AAL. Blocks will amplify the problem and as they move the fulcrume point where the axel mounts on the springs, thus leading to premature wear on the springs. In many cases if the block is poorly made, they can shatter, crack, or whatever and cause a big problem.<<<this post in another forum from a very WISE Man on technical stuff-"Chris 4x4"..........this is your answer-no cause for great concearn
Old 05-14-2008, 10:30 AM   #4
lsocoee's Avatar
there is a part of the drivetrain that allows for a very slight change in length due to the suspension travel. As the truck slows quickly, the rear goes up. As you accelerate, the rear goes down. This change in height is what causes the change in effective driveshaft length. The part that allows the change in length(and causes the clunking) might have a stiff grease causing the problem.
True, a change in suspension could also help with the issue.
Old 05-14-2008, 11:54 AM   #5
My other ride weighs 200 tons
4x4x4trd is one of the sharper tools in the shed4x4x4trd is one of the sharper tools in the shed4x4x4trd is one of the sharper tools in the shed4x4x4trd is one of the sharper tools in the shed4x4x4trd is one of the sharper tools in the shed4x4x4trd is one of the sharper tools in the shed4x4x4trd is one of the sharper tools in the shed4x4x4trd is one of the sharper tools in the shed4x4x4trd is one of the sharper tools in the shed4x4x4trd is one of the sharper tools in the shed4x4x4trd is one of the sharper tools in the shed
4x4x4trd's Avatar
4x4x4trd's Tacoma Gallery
Any help?
Kinda off topic, but I greased the slip yoke bushing on my '99 Tacoma 4X4 with brand X. Started clunkin while taking off and stoping. Took it to the dealer and they said they repacked it with their Toyota grease and it did help. Six months later the bushing needed replacing anyway for excessive play. All I'm saying grease or defective my problems were with the slip yoke bushing. This caused a cluncking noise and a small surge type feeling upon occasion.
99 4cyl tacoma 6" lift, transmission? chasers87 1st Gen. Tacomas 1 01-02-2011 01:34 PM
99 Prerunner Rear Shocks Question Anthony250 1st Gen. Tacomas 1 12-25-2010 05:15 PM
02' Prerunner Transmission Question PrerunnerPaul 1st Gen. Tacomas 0 11-15-2010 07:58 PM
99 tacoma Transmission swap from 4runner? bombers_2007 1st Gen. Tacomas 0 10-05-2009 05:16 PM
TW: 99 Tacoma PreRunner Tooyoung Buy / Sell / Trade 4 07-20-2009 03:47 PM
