P0171 code help needed
Old 06-24-2010, 06:43 PM   #1
crazyscout [OP] crazyscout is offline
crazyscout is on a distinguished road
Army:
crazyscout's Tacoma Gallery
So my check engine light came on. I had replaced o-rings on 2 fuel injectors and it was working fine. Drove 2 hours to a party, sat there for a few hours, then drove back. It came on as soon as I got home. I changed the spark plugs the next day, I was going to anyway, and it went off for a while. Since then, I've cleaned the MAF sensor, inspected the intake system for cracks or leaks, reset the ECM, and run through a full tank of gas with fuel injector cleaner....any suggestions what to try before I start replacing sensors? I was told it could be the coolant temperature sensor, O2 sensor, MAF sensor, or the MAP sensor. If there's nothing else to try I'm going to go through and test, then replace them in that order
Old 06-25-2010, 07:51 AM   #2
Banned
BlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shedBlueT is one of the sharper tools in the shed
BlueT's Tacoma Gallery
Check PCV valve and the PCV rubber line for it for cracks, stuck open etc..
Old 06-25-2010, 08:29 AM   #3
OCTaco is one of the sharper tools in the shedOCTaco is one of the sharper tools in the shedOCTaco is one of the sharper tools in the shedOCTaco is one of the sharper tools in the shedOCTaco is one of the sharper tools in the shedOCTaco is one of the sharper tools in the shedOCTaco is one of the sharper tools in the shedOCTaco is one of the sharper tools in the shedOCTaco is one of the sharper tools in the shedOCTaco is one of the sharper tools in the shedOCTaco is one of the sharper tools in the shed
OCTaco's Avatar
Army: MP
OCTaco's Tacoma Gallery
Have you looked up the code?
Here's what this guy did
http://www.tacomaworld.com/forum/1st...obd2-code.html
P0171 CEL Code Greensystemsgo 1st Gen. Tacomas 23 03-27-2014 11:59 PM
Code P0171 Flaadog Technical Chat 10 10-28-2011 06:58 AM
CEL CODE P0171 harley09 Technical Chat 28 10-13-2010 12:38 PM
P0171 Code shaniac 1st Gen. Tacomas 9 08-18-2010 10:19 PM
code p0171 trailinTaco 1st Gen. Tacomas 1 06-23-2009 09:23 PM
