-   -   5vz-fe removal (http://www.tacomaworld.com/forum/technical-chat/10369-5vz-fe-removal.html)
cope 06-18-2008 04:35 PM
5vz-fe removal
im putting a new engine in a 99 tacoma v6 5-speed 4x4 and i cant get the engine to seprate for the trans.
i know it has to slide foward quite a bit to clear the trans shaft befor it will come up and out but it won't separate at all i cant get anykind of gap between the engine and trans anybody have any tips or info?
i have tripple checked everthing all bellhousing bolts are out,motor mounts are out it just wont come apart
ShrockTaco 06-21-2008 02:11 PM
the clutch should not get in the way of removal if you havent already pull the radiator out .. put a flat pry bar between bell housing and engine block and give it a nudge. the input shaft on 5spd trannys is only about 6" long
