-   -   Whoops did I need that - (Ball Joint) (http://www.tacomaworld.com/forum/technical-chat/106549-whoops-did-i-need-ball-joint.html)
Farva 08-04-2010 02:24 PM
Sooo I just replaced my right side ball joint and happened to stumble across this page...
http://www.parksoffroad.com/tacomamo.../balljoint.htm
after the fact.
If you scroll down a little on there you'll see he talks about sliding that "little ring" off the old ball joint...
Was that to slide it back on to the new ball joint before hooking it back up to the UCA? If sooo I may be screwed, because I did not.
In fact the "little ring" was quite bent when I removed the dust boot from the old ball joint.
Thanks so much for any advice!
