INSTRUMENT cLUSTER LIGHTS NOT WORK
Discussion in 'Technical Chat' started by Alexis(TRD), Aug 9, 2010.
  1. Aug 9, 2010 at 10:28 AM
    Alexis(TRD)
    Alexis(TRD) [OP] Member
    Alexis
    Puerto Rico
    TRD PreRunner SR5
    I INSTALL A KENWOOD EXCELLON, AND THE CLUSTER LIGHTS NOT WORK:confused:
  2. Aug 9, 2010 at 10:30 AM
    98tacoma27
    Ben
    Not Beech Creek
    Just the cluster lights, or are other lights not working also? map lights, turn signals, etc.
  3. Aug 9, 2010 at 10:35 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Fuse!
  4. Aug 9, 2010 at 12:13 PM
    Alexis(TRD)
    Alexis
    Puerto Rico
    TRD PreRunner SR5
    nop, only the cluster lights not work, i'm ck all fuse i'ts ok
  5. Aug 9, 2010 at 12:14 PM
    Alexis(TRD)
    Alexis
    Puerto Rico
    TRD PreRunner SR5
    only cluster lights
  6. Aug 9, 2010 at 12:18 PM
    98tacoma27
    Ben
    Not Beech Creek
    You will have to recheck your wiring because the ground may have been lost. Just to be safe, make sure the dimmer is turned the right way.
  7. Aug 9, 2010 at 12:28 PM
    Alexis(TRD)
    Alexis
    Puerto Rico
    TRD PreRunner SR5
    ok, with the light switch turn on on park turn on cluster, but the switch to headlamp the light on cluster turn off, sorry for my english... i'm speak a little english
  8. Aug 9, 2010 at 12:37 PM
    misterquad
    misterquad Well-Known Member
    Shawnee, KS
    You checked BOTH sets of fuses. Under hood and in dash?
  9. Aug 9, 2010 at 12:40 PM
    Alexis(TRD)
    Alexis
    Puerto Rico
    TRD PreRunner SR5
    yes i ck both side:mad:
  10. Aug 9, 2010 at 12:50 PM
    98tacoma27
    Ben
    Not Beech Creek
    Turn the lights on with the key in the ON position. Then turn the dial on the left side of the dash clockwise.
  11. Aug 9, 2010 at 12:55 PM
    Alexis(TRD)
    Alexis
    Puerto Rico
    TRD PreRunner SR5
    sorry, i'm confused, when the light swtch turn off the cluster work, but when turn the first or the end the cluster turn off......:confused:
    please help me.... i no see anything in the night :mad::mad:
  12. Aug 9, 2010 at 2:25 PM
    Alexis(TRD)
    Alexis
    Puerto Rico
    TRD PreRunner SR5
    Somebody helpmeeeeeee!!!!!
  13. Aug 9, 2010 at 2:44 PM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    16 Super White Limited 4x4
    You probably shorted the Dimming wire in the stereo wiring harness. Disconnect it from the HU and see if that fixes it. If it does then you have it wired wrong.
  14. Aug 9, 2010 at 2:45 PM
    Alexis(TRD)
    Alexis
    Puerto Rico
    TRD PreRunner SR5
    what its hu?
  15. Aug 9, 2010 at 5:25 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    HU = headunit (your stereo, the KENWOOD EXCELLON)
  16. Aug 13, 2010 at 3:37 PM
    00taco
    00taco Well-Known Member
    Casey
    cali
    black 00 tacoma v6
    wheels, tires, sound system, hid headlights, 1st gen fog light mod, tinted tails hella 500s on custom light bar, dust light, led white guages/dash lights, color matched grille, exhuast, blacked bumper and accents....
    if your dimmer switch plug on the harness is loose then the lights wont come on check it make sure its on tight
