-   -   4.0L 1GR 2nd Gen Oil Change Guide (http://www.tacomaworld.com/forum/technical-chat/11201-4-0l-1gr-2nd-gen-oil-change-guide.html)
chris4x4 07-08-2008 04:53 PM
(See 3.4L 5VZ 1st Gen oil change for 1st Gen Tacomas)
The oil filter for the 2.7 second gen is: 90915-YZZG1 (the following part numbers are equivalent:
90915-YZZG1, 08922-02011, 90915-YZZD1, 90915-YZZD1-DS)
Oil filter for the 4.0 second gen is: 90915-YZZD3
Make sure you have all you need for your Oil Change:
Oil filter
Oil filter wrench
New oil plug gasket (available from dealer)
5.5 quarts of oil
5/16" ID 5ft long tube
14mm socket wrench
Oil pan
Oil funnel
http://i207.photobucket.com/albums/b...oilchange1.jpg
Remove the plug at the bottom of the filter holder:
http://i207.photobucket.com/albums/b...oilchange6.jpg
Connect a 5/16" 5 foot long tube to the filter drain, and run it to your Oil catch pan. Useing a filter wrench, remove the filter:
http://i207.photobucket.com/albums/b...oilchange9.jpg
http://i207.photobucket.com/albums/b...ilchange10.jpg
Clean the filter mount to get the dirty oil that sleft in it, out.:
http://i207.photobucket.com/albums/b...ilchange11.jpg
Put the filter holder plug back on. Lube the new filter seal with a light film of oil:
http://i207.photobucket.com/albums/b...ilchange12.jpg
Install the new filter. Hand tight, then 1/4 turn:
http://i207.photobucket.com/albums/b...oilchange2.jpg
Get a 14mm socket, and find the Oil drain plug under the truck:
http://i207.photobucket.com/albums/b...oilchange7.jpg
After breaking it loose, remove it and let the oil drain out:
http://i207.photobucket.com/albums/b...oilchange8.jpg
After the Oil drains out, with a new gasket on the drain plug, reinstall the plug in the Oil pan and torque to 30 lb-ft:
Then, Fill with 5.5 Quarts of your favorite oil:
http://i207.photobucket.com/albums/b...oilchange3.jpg
Run the engine for a couple of mins. and check the level:
http://i207.photobucket.com/albums/b...oilchange4.jpg
Dont forget to recycle your used motor oil.
Many Auto parts store will accept your used motor oil for recycling. Check you phone book.
:D
deadbolt 07-08-2008 05:06 PM
what size is the filter cap remover
chris4x4 07-08-2008 05:09 PM
I cant remember.....:o
I have a set, and its the medium one. :D
chris4x4 07-08-2008 07:26 PM
BUMP. I think this is a good idea. :)
tacomaman06 07-08-2008 07:37 PM
i think ita a good idea too. we should make this a sticky!!
raycie 07-08-2008 07:50 PM
Crap.. that's how the oil comes out of that resevior... I used the 'ol soak it up with a rag technique.. (no wise a*s remarks please...)..
Also just picked up a craftsman oil filter adapter that adapts to various sized filters..
hillbillynwv 07-14-2008 08:31 AM
Thanks for the info about the plug at the bottom of the filter holder. I have not change my oil yet since I only have 1,100 miles. I never knew that was there thanks for the info.
spaghettiedy 10-14-2008 11:51 AM
This would be a good sticky
Zombie Runner 10-14-2008 12:23 PM
running a tube to the bottom of the filter holder is a good idea...I just coverd the thing with a plastic wal mart bag...free...easy...
Dark Knight 10-14-2008 12:48 PM
agreed. I have just been using a 16oz water bottle, but still end up spilling it some times, going to get some tubing for the next time for sure! Bump for Sticky or for other people.
Agent475 10-14-2008 01:20 PM
Good idea - great thread - STICKY!!
P.S. You could add to it with info on oil types and selection as well as filter selection etc...
Flyguy 10-15-2008 05:39 PM
Oil Plug
:confused:As you face the oil drain plug on your back ,as your feet extend out from under the front grill ,It still is lefty Loise- rightie tighty right? Would really hate to strip that sucker.
chris4x4 10-15-2008 05:40 PM
Yep! If it helps, set the ratchet before turning the bolt, just to be safe. :)
MT_mudflaps 10-28-2008 06:16 PM
I should've looked at this last night before I changed the oil for the first time -- oh well!
Good post though!!!! I agree it should be sticky-fied!
monoman 10-30-2008 10:52 AM
Man, I sure wish my oil filter was that easy to get to! ( I have the 3.4) I like that little shield that is around the base of the filter.:thumbsup:
DFPTaco 10-30-2008 11:12 AM
Sweet, I didn't know about the filter drain thingy. That'll save a mess in the future...
Anybody know the part numbers for the larger size mobile 1 oil filter???
kris77 10-30-2008 11:24 AM
I made a huge mess when i changed my oil last month...I never knew that little plug was under the filter...I did what raycie did...I had to mop it up with paper towels and rags...
See....You learn something new every day...
perniva1978 11-03-2008 09:44 PM
I used to do my own oil changes since I was in high school (1994) until I got to own my 2004 Tacoma V6. I did 1 oil change and then I gave up. It's too uncomfortable. Looks like your pictures are for a 4-cylinder Tacoma and it might be easier than changing the oil on a V6.
chris4x4 11-04-2008 04:39 AM
Welcome to Tacoma WOrld! The pics are from the 1GR-FE V6. :)
