-   -   tranny problems (http://www.tacomaworld.com/forum/technical-chat/130-tranny-problems.html)
Bud 10-30-2006 09:14 AM
tranny problems
I've been experiencing the same problems with the Tacoma 06 V6 5sp auto tranny shift up and down unnessarily when using the cruise control and then it suddenly increasing the set speed by 10 or more K on flat level highway. Scared the heck out of me. If I drive slowly at posted speeds without the cruise control engaged my best mileage is 20 mpg. but it's usually around 18to 19 mpg. From a dead stop at the lights with brakes engaged you are able to feel the truck wanting to jump or lurch forward. You really need to be aware that your foot is into that pedal when stopped. Also have the shuddering problem from quick acceleration and deceleration when using the transmission shifting from 5 to 4 while applying brakes. It almost feels like the rear end shuddering. We just had are first snowfall of the year and I've had an opportunity to drive in some crappy conditions just the last couple of days using the 4 wheel drive. With the current factory tires Bridgestone Dueler H/T 265/65R17. Terrible on snow and ice, Tacoma was having real problems with traction on the corners and even manueuvering through the parking lots. I would not trust those tires to get me out of a ditch. I've defiendly got to purchase some winter tires and put them on winter rims. (any suggestions would be helpful).
twoarezee 10-30-2006 11:12 AM
i believe the 05+ auto transmissions are built to mimic a manual transmission. they up shift and downshift at points where the driver would shift if driving a 5/6 speed.
ForeRunner 10-30-2006 11:16 AM
You Sir are correct. I also recommend getting some decent winter tires on the rig. Mine came with the BFG All Terrian's and they work really well for an all around tire.
Sandman614 10-24-2013 04:19 AM
Dammit Tapatalk...
