Rear bumper replacement?
Discussion in 'Technical Chat' started by kj6cm59, Feb 22, 2011.
  1. Feb 22, 2011 at 8:02 AM
    kj6cm59
    kj6cm59 [OP] Active Member
    Huntington Beach
    tacoma 4x4
    TRD cold air and exhaust
    Can't believe I backed into a poll! How hard is it to install a new bumper? Also cracked the tail light!!
  2. Feb 22, 2011 at 1:27 PM
    BlueSteel
    BlueSteel Well-Known Member
    James
    The Woodlands, TX
    09 Magnetic Grey Doublecab TRD Sport Debadged
    Camburg 4" Spindles, Icon CB 2.5 adjustables front and rear, Total Chaos Upper/Lower CAs, Alcan 5" Rear Leafs, Timbren Bumpstops, 5" SS Brakelines, 295/70/18 Nitto Trail Grapplers on 18" KMC Monsters, Grill Craft Black Mesh Upper, Predator Running Boards, All Pro Rear Bumper and Hitch, Wet Okole Covers, Toyota Roof Rack, Limo Tint, TRD CAI, TRD Exhaust, Weathertech Mats, Redline Hood Struts, Red Top Odyssey battery, BDF Light Bar, Foglight anytime Mod, Lo Pro QT Truxedo Tonneau cover, Rocky Mount Bike Pegs.
    That is my current delimma right now because someone backed up into my rear bumper and split. I'm looking at the All-Pro, Relentless, or Road Armor Bumper. The Road Armor bumper is the only one that I can find out that works with the factory hitch. All the others you must remove your factory hitch.
  3. Feb 22, 2011 at 1:28 PM
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    Go with Relentless or Elite Bumpers for sure. support TW Vendors.
  4. Feb 25, 2011 at 11:46 AM
    timkins42
    timkins42 Well-Known Member
    Tim
    Fishers, NY
    2021 Black Tacoma 4X4 TRD Sport Access cab
    None so far
    I just pulled the rear bumper on my 2010 Tacoma yesterday. Its not really too bad to complete. If you have the plastic steps on the bumper be careful as they will break very easily, no need to remove the plastic overlays on the corners of the bumper. In all there is about 10 bolts 10mm in size that need to be removed. If you have a trailer hitch add another 2 19mm bolts to that. You need to carefully remove the plastic steps and then remove the 6 bolts undreneath and then remove the 4 bolts from the bottom and pull the bumper back slowly and then remove the license plate lights by turning 1/4 turn.
  5. Feb 25, 2011 at 8:06 PM
    kj6cm59
    Huntington Beach
    tacoma 4x4
    Thanks, very helpful I will attempt it this weekend!
