installing fog lights
Discussion in 'Technical Chat' started by jack18, Mar 1, 2011.
  1. Mar 1, 2011 at 2:21 PM
    jack18
    jack18 [OP] New Member
    jack
    2011 tacoma access cab want to hook up oem fog lights did not come with truck. After searching i have the wires down inside the bumpers that are capped off,and pulled out the blank where the switch would go on the dash and that has wires on it for switch. and i guess i need a to buy a relay to plug in the fuse box.toyota does not sell a fog light kit so i have to buy everything seperate.is there anything else
  2. Mar 27, 2011 at 3:47 PM
    jack18
    jack
    It was the base access cab V6. Already have hooked up the fog lights and used oem equipment. the whole job took about 45 mins.
  3. Mar 27, 2011 at 5:48 PM
    jrdbrn
    jrdbrn Well-Known Member
    Jared
    Louisiana
    '21 TRD Off Road
    Where did you buy the lights and switch/relay?
  4. Apr 13, 2011 at 6:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Most get them off Ebay.
  5. Oct 1, 2012 at 6:34 AM
    Bently
    Bently Active Member
    Scott
    2011 black tacoma
    fog lights installed tri fold tonneau cover Folding towing mirrors
    My after market fog lights in my 2011 tacoma were working friday but they not working now. I checked the fuse , bulbs, switch, What am i missing?
  6. Oct 1, 2012 at 6:38 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Are they newly wired or do they use the factory wiring? If it's factory wiring, there's a relay under the hood that could have gone bad as well. My guess would be your fuse is out, try changing the fuse with one that you know is working just to be sure. Next, I would start chasing your problem with a test light to see where you have power and where you don't. Start with the light sockets themselves, then the switch, then make sure you have power at the fuse and through the fuse, then check the relay.
  7. Oct 1, 2012 at 6:41 AM
    4banger09
    4banger09 Well-Known Member
    Alex
    Nb, Canada
    09 Tacoma Access cab 4cyl
    Leveled
    Bought my whole kit off Amazon for 90 bucks here's the switch only problem is it lights up green.
    520F7BE9-724C-42D9-9138-8E0BA5BEC387-499_d1aa04c2105b2c721c5a6b7f01e4bcb5518d82b7.jpg
  8. Oct 1, 2012 at 6:45 AM
    Pugga
    Massachusetts
    Your switch is upside down :anonymous:
    Also, if that is an OEM style switch, you can swap out the bulb very easily so it matches the other switches. It only takes a small flat-head screw driver to do so.
    In this picture, the brown round thing you see on the side of the switch is the small incadescent light. It twists out with a small screw driver and you can replace it with whatever color you wish.
  9. Oct 1, 2012 at 7:09 AM
    4banger09
    Alex
    Nb, Canada
    Leveled
    Hmmm, shiiiiiiiiiiiiiiiiiiiiiiiiiiit oh we'll I can't see it anyway. Just flip your monitor upside down that's what it looks like. And I could care less what color it is just letting the guy know it wasn't the factory orange.
  10. Oct 1, 2012 at 7:13 AM
    Pugga
    Massachusetts
    I flipped my monitors upside down and your fog light switch was right-side up! But... your your clutch start-cancel, RSCA, VSC and mirror adjustment buttons are not upside down. Also, did you know that you have floor mats on your roof? :laugh:
  11. Oct 1, 2012 at 9:25 AM
    4banger09
    Alex
    Nb, Canada
    Leveled
    I'll have to do a write up on my cab conversion later
  12. Oct 2, 2012 at 4:23 PM
    Bently
    Scott
    2011 black tacoma
    it was a bad relay...:)
  13. Mar 9, 2013 at 11:08 AM
    Aeon
    Aeon FOX HOUND
    Puerto Rico
    PreRunner SR5 4x2
    Coming Soon!
    hi everyone
    where i can buy the complete kit ?
    let me know :
    thanks
  14. Mar 13, 2013 at 5:36 PM
    Bently
    Scott
    2011 black tacoma
    I got my lights and relay off of ebay and the switch from my toyota dealer
  15. Jan 3, 2015 at 12:49 PM
    sbates
    sbates Well-Known Member
    Steve
    NJ
    2011 Tacoma TRD Sport Double Cab
    Extang Tonneau Cover, aFe Pro Dry S air filter, Weathertech Floormats, De-badged, Plasti dipped Toyota emblem black, Plasti dipped a/c control panel black, 48-led Dome Light, Tailgate Damper,
    Digging into an old thread. Can anyone tell me the part # for that little light inside the switch? Mine burned out and needs to be replaced. I doubt autozone would have something like this.
  16. Jul 16, 2016 at 6:49 AM
    MicahW95
    MicahW95 Member
    Micah
    2009 Toyota Tacoma TRD 4x4
    HID Kit Exhaust Mod Running light and side markers Led Conversion.
    Hello, I'm trying to do a HID conversion on my fog lights. I have a 2009 model Tacoma and can't seem to find anywhere on YouTube or on Tacoma world regarding the proper way to remove the fog light from the bumper. I can't seem to get it myself and struggling to find some good Intel. If someone could post a picture or video showing this it would mean a lot. Thanks
  17. Jul 17, 2016 at 12:01 AM
    edmar651
    edmar651 New Member
    ed
    New York
    2015 Tacoma
    I am in the middle of installing fog lights on my 2015 base Tacoma. I have the lights in and the OEM switch is installed (lights pre-wired). I need assistance with the 12 volt relay. What do I need (specs) and in looking at the fuse box there is actually two available locations for the relay....any thoughts on which is the right one? Sorry if this all sounds idiotic, but the local dealership has been of little assistance.....so reaching-out here for help.
