Severe Binding - What Am I Doing Wrong?
Discussion in 'Technical Chat' started by CrazyOzzy, Mar 28, 2011.
  1. Mar 28, 2011 at 7:24 AM
    CrazyOzzy
    CrazyOzzy [OP] New Member
    Beaverton, OR
    09 TRD OffRoad
    When I'm in snow and stuck, I experience severe binding of the drive train.
    I'm now sure what’s up. I'm in 4x4 and
    all tires are spinning. I’m only in
    about 1 1/2’ of snow. Alarms are heard
    like the traction control is engaged.
    The engine bogs down and everything seems bound up. I let off the gas and can start moving again
    but then the same thing happens. Tires
    start spinning and then bogs down. I’m
    stuck. I’ve tried disabling traction
    control. I’m new here and any help is
    appreciated.
  2. Mar 28, 2011 at 7:47 AM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    4hi or 4lo? And welcome. :)
  3. Mar 28, 2011 at 7:59 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Did you try going in reverse??
    Was that 1.5 FEET of snow? That's a lot of snow to try and plow through. Not sure you'll ever be able to make it thru it unless you can drive OVER it.
    Was your locker engaged?
  4. Mar 28, 2011 at 8:05 AM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Are you turning the wheel hard to either side? That will bind it for sure. If you're not turning the wheel, you have an issue I'm unfamiliar with.
  5. Mar 28, 2011 at 8:35 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    To disable the traction control , did you just push the button , or push and hold for 5 seconds ?
    These produce different results .
