engine block drain plug on 4 banger???
Discussion in 'Technical Chat' started by RaiderSix, May 18, 2007.
  1. May 18, 2007 at 9:43 PM
    RaiderSix
    RaiderSix [OP] Well-Known Member
    I can't find the coolant drain plug that the Haynes manual talks about on page 1-32. I am doing a radiator flush tommorow and want to be thorough since it has never been done to this truck. The line drawing picture has an arrow pointing to it, but it is way too vague.
  2. May 19, 2007 at 8:21 AM
    EvilBetty
    EvilBetty Well-Known Member
    Kansas City, MO
    07 SR5 Access Cab
    Visor CD Holder
    What year? On my 94' 22RE 2.4 it was just a little white plastic winged plug on the bottom inside corer of the radiator.
    If you were facing the grill it was on the left side at the bottom on the side between the engine and the radiator.
    I do remember it being hard to see, but you cant miss the feel of that plast wing nut.
  3. May 19, 2007 at 5:03 PM
    RaiderSix
    It's a 97 2WD model. I gave up on finding it and just drained it at the radiator tap. The antifreeze was black like old brake fluid. I'm going to run some Zerex Super Cleaner through it during the weekend. Hopefully I can get most of the gunk out and be able to have clean antifreeze.
  4. May 23, 2007 at 8:02 AM
    RaiderSix
    Well, I flushed my radiator out real good. I went from black antifreeze to nice green antifreeze. The Zerex super flush stuff worked pretty good. I ran that stuff in there for 400 miles (6 hour drive) and then put one of those garden hose flush kits on and got the gunk out of the cooling system. With the radiator cap off you can see the shiny metal of the inside of the radiator core. Pretty impressed with that flush chemical. Now my next project is to check/adjust the valves and regrease the wheel bearings. :D
  5. May 23, 2007 at 8:54 AM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Well, you will have a brand-new truck pretty soon! ;)
