Quick Links: Bolt size for step bars How To - Change Spark Plug 1st Gen 95.5-04 2RZ-FE(2.4L)/3RZ-FE(2.7L) Trick to Pulling Pins from Gen2 4wd Switch Plug TRANSMISSION . Transmission coolers for all Toyotas ... Write up with many pictures Anyone install a "pusher" fan on their V6 2nd Gen? How many amps to run in fuse
strange ratat ta tat engine noise
Discussion in 'Technical Chat' started by tacocrazychris, Sep 8, 2011.
