-   -   05+ DRL Enable/Disable Switch (http://www.tacomaworld.com/forum/technical-chat/19468-05-drl-enable-disable-switch.html)
007Tacoma 11-23-2008 09:34 AM
After my write-up on how to install Daytime Running Lights (DRLs) on an 05+ Tacoma, tons of members have been asking me how to disable them via a switch or permanently. Well, it is quite simple.
First, read how to install them here...
05+ DRL (Daytime Running Lights) Install OEM
That will show you how to get to the backside of the computer module underneat the dash. To get to the wiring harness and DRL control module.
http://www.tacomaworld.com/gallery/d...ire_to_cut.jpg
On the wiring harness that we install in that tutorial, there is a GREEN wire with a RED stripe coming from the DRL control unit going to the main control unit (see picture below). This wire is the main power for the DRL circuit. If you disable this circuit, you can disable the DRLs without affecting your Hazard lights or your Turn Signals adversely.
http://www.tacomaworld.com/forum/../...0/IMG_1597.JPG
http://www.tacomaworld.com/forum/../...0/IMG_1598.JPG
The Green wire with the Red strip is going to go from the white connector to the DRL control module. This wire is only one of three wires coming from this particular connector.
http://www.tacomaworld.com/forum/../...0/IMG_1600.JPG
I then soldered and heat shrink'ed a wire at each end going to a switch. This way I can enable/disable the DRLs at will.
At the moment, I have a very crappy Radio Shack 12v toggle switch controlling the DRLs, but I suggest that you invest in a switch that will look closer to OEM such as one of these:
http://www.oznium.com/gsw-45 ...which was suggested by Keason1*
http://www.oznium.com/product_photos/large/2774.jpg
Teufel Hunden 11-23-2008 03:38 PM
Great write-up again 007Tacoma! Thanks! I have a question relating to the DRL's that I need help with. I recently installed the DRL kit using your instructions (another great write-up). I have decided that I am going to purchase the Muth heated signal mirrors. My question is, where can I wire the signal lights for the mirrors so that they won't be on all the time, since the front signal lights are now always on for the DRL's? I imagine I will have to use the wires for the rear signal lights, but I do not have a wiring diagram, so I don't know where those are. Do you know where in the dash assembly the wires are located for the rear signal lights? I have a 2009 Tacoma Double-Cab. Thanks in advance for any help that you can give.
007Tacoma 11-24-2008 05:34 AM
If I were doing it, I would wire them to the rear lights. Let me see if I can't dig up a wiring diagram for you...
Teufel Hunden 11-25-2008 07:05 AM
Thanks! That would be great! I appreciate any help you can give!
007Tacoma 11-25-2008 11:20 AM
Tacoma In-Depth Wiring Diagram
Check this FSM (Factory Service Manual) for a wiring diagram...
http://www.ncttora.com/fsm/index.html
If that does not work, I can email you a zipped folder of PDF files.
08WhiteTRD 11-25-2008 11:23 AM
You guys just keep adding to my to-do list!!! This is a great write-up and I will have to look into doing this one.
Teufel Hunden 11-25-2008 03:05 PM
Thanks! I really appreciate your help! That link worked just fine. One more question though: The latest wiring diagram is for the 2007 model year, I read somewhere in the forum that the wiring for the 2008's and newer are a little different than for the 2007's and older, do you know if this is true? Has the 2007 wiring diagram worked just fine for your 2008?
007Tacoma 11-26-2008 06:27 AM
There are a few additions for the 2009 MY, but for the most part (especially the lights) the wiring is going to be the same.
LEDtoma 02-17-2009 01:03 PM
DRL mod
007Tacoma,
Awesome write-up and thanks. Everysince the '08 Nascar session started and most tracks choose to use the Tundra, I said I have to have those lights. My Taco looks freaking awesome and getting alot of complements here on the East coast. One question though, if I do this "enable/disable mod" will my "parking lot mod" work when the DRL install is disabled?
007Tacoma 02-17-2009 01:23 PM
Originally Posted by LEDtoma (Post 403289)
007Tacoma,
I have a feeling I may regret asking this, but which "parking lot mod" are you talking about?
LEDtoma 02-18-2009 07:07 AM
Dis-regard. I did the DRL mod last night and all is well, thanks again. FYI - the "parking light mod" has been in circulation since I bought my '05. Got the write-up from Pb2theMax @ Cardomain.com, so check there. Thanks again for helping tweak the OEM DRL install Toyota should have added! By the way, take a look at this switch, required very little fabrication from the Dremel. I used for my "bed light mod" and choose a double pole so I could have complete control from the cab and still through 12V's to the bed for a switch there. There are single pole non-illuminated...
http://www.jmsonline.net/CONTURA-SWITCH-ON-OFF-ON.htm
PB2theMax - this guy is blessed with talent and knowledge ...
http://www.cardomain.com/ride/832238
JohnMoose 03-13-2009 04:19 PM
Disable '09 driving lights
Hello. I'm looking for info about disabling the Daytime Driving Lights on the '09. I've had the truck since Dec, and I can't get the dealer to kill'em.
LEDtoma 03-16-2009 06:46 AM
[quote=JohnMoose;463606]Hello. I'm looking for info about disabling the Daytime Driving Lights on the '09. I've had the truck since Dec, and I can't get the dealer to kill'em.
Thanks[/quote
Life seems funny like that...I wanted DRL's and you didn't. My '05 4Runner Sport came with an auto-lock/un-lock feature that would automatically lock/un-lock all doors after the engine was started or turned off. My dealer gladly$$ charged me to un-install the Toyota OEM relay. I would guess that one install over the other I did were both time consuming, but installing a "kill" switch took me the least amount of time and money on my '05. I'm not sure if the '09 models added more features that would accept the '05 OEM relay I replaced. So please check with 007Tacoma or someone with more schematic background. The rocker switch I installed was just a commodity 12V un-illuminated switch from Radio Shack I mounted under my dash. See 007's write up on the install and good luck.
http://www.radioshack.com/product/in...ductId=3016149
http://www.tacomaworld.com/forum/tec...stall-oem.html
Griztaco 04-26-2009 03:05 PM
How do these wires attach to your switch, my switch has three screws were I can attach only two ends of the wire, so which goes where?
007Tacoma 10-21-2009 05:33 AM
Sorry it took me so long to respond. I didn't realize that I wasn't subscribed to my own thread! :eek:
I didn't attach the third wire as I didn't want the LED on all the time (its pretty bright). There should be model specifications as to which leads you should hook up that came with the switch. If you got the oznium lights, the specifications are on their website.
charliegates 05-17-2010 09:40 PM
Drl
I just completed the DRL mode for my 2009 DC Tacoma. I did not install the switch as I purchased the wrong switch. However we spliced the power supply for the DRL and tested it several times by shorting it. Everything works fine. I am going to get a switch soon but I would like to thank 007tacoma for his excellent documentation.
Crom 05-20-2010 10:54 AM
Wow! I searched and searched but I obviously couldn't find this thread. I did it all on my own and made a similar thread here:http://www.tacomaworld.com/forum/lig...alth-mode.html
007Tacoma, Thanks for showing the picture with the harness taken out. I did my work with the harness left in place. It would have been a lot easier to take it out like you did.
Also, I should note the the wiring coloring did change on the 1M plug in the 2009 models, just ever so slightly though. See the link above for details.
Gregman 06-18-2010 06:52 AM
I would like to install a switch as described above to disable my DRL.
My low beam headlights and the amber lights are both on when the truck is running but I would prefer to have just the amber lights on and the option to turn those off. (need to have the truck running with the heater and sterio on but no exterior lights, of course this is for stealth parking options with the girlfriend you understand)
So is the modification described in this thread just for the amber lights, or will it also turn off the low beam headlights also?
My '05 came from Florida and I bought it from a used dealer in Canada so I am assuming the DRL mod was installed during or before importing.
Thanks for any advice, I appreciate it.
Crom 06-18-2010 09:25 PM
Greg, welcome to the forums! I am afraid that there may be differences between the Canadian version and the U.S. version. The U.S. version does not have low beams on and amber at the same time like yours...
The wire mod in this thread may or may not work for you. But it does however control the amber lights for us.
A wiring diagram for your model and year truck should authoritatively answer your question.
