Check engine light not fixed by replacing o2 sensor??
Discussion in 'Technical Chat' started by sbvaughn88, Feb 4, 2009.
  1. Feb 4, 2009 at 7:10 PM
    sbvaughn88
    sbvaughn88 [OP] Member
    Grove City, OH
    4dr Sr5 V6 TRD
    Hello,
    I am new to the forum but have heard really good things...To sum up my issue. I bought my second taco from a guy a few weeks ago and the check engine light was on...he told me it was the downstream 02 sensor which I bought for 100 bucks and replaced thinking this would solve my problem. I them went to advance to have the code turned off and it showed P0440 and a few others I cant remeber. The truck runs really good and seems to get good mileage- no sputters or lags...just wondering what to do next?? I am praying to god it is not the cat. I have a 30 day tag and will be registering the vehicle in TN where I do have to pass emissions. Any Ideas??
  2. Feb 4, 2009 at 7:14 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Where did you get your sensor from? I've heard non-oem sensors are hit and miss.
    Anyway, Welcome to TW!
  3. Feb 4, 2009 at 7:15 PM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    Look up what the codes mean first. Otherwise you're just replacing parts at random. What generation Taco is it?
  4. Feb 4, 2009 at 7:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The most common cause of the P0440 code is a loose gas cap. Tighten it, pull the negative cable for a half hour, and you should be good.
  5. Feb 4, 2009 at 7:35 PM
    sbvaughn88
    Grove City, OH
    4dr Sr5 V6 TRD
    The part was a Bosch I bought from Advance and it was a direct plug in. Also the truck is a 2002 V6 TRD. The install went clean...did I mention the guy erased the code and it came back in about 3 minutes?? not sure if thats relevant....I will go tommorrow and check the codes again. Does anyone know what code comes up if the cat is bad??
  6. Feb 4, 2009 at 8:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Correct. Most probable causes:
    Remove and reinstall the gas cap, clear the code, and drive for a day and see if the codes come back.
    Inspect the EVAP system for cuts/holes in tubes/hoses
    Inspect for damaged or disconnected hoses around the Evap purge solenoid
    Check and/or replace the sensor
    Check and/or replace the purge valve
    Have a professional use a smoke machine to detect leaks
  7. Feb 5, 2009 at 5:41 PM
    pb4ugotobed
    pb4ugotobed Well-Known Member
    Are you saying the P0440 code came back on in about 3 minutes? Or that the light just came back on in about 3 minutes? It's VERY unlikely that you could set an EVAP code that quickly after clearing it... it takes the computer longer than 3 minutes to perform the evap test... and it's 2 trip logic so just failing the test the first time won't turn on the MIL.
    A bad 02 or A/F sensor could very likely still be the culprit here, however you need to provide us with what codes are stored in the system. It's also very likely that the 'guy' you bought the truck from diagnosed the wrong sensor as being bad. More info would be beneficial to you :)
  8. Feb 5, 2009 at 6:15 PM
    dud122
    dud122 rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
    i have aa NIB A/F sensor for an 02 tacoma V6 if you need one... let me know i can give you a deal on it
  9. Feb 5, 2009 at 6:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Run smoke (I use a cigar) along the emision lines to see if its drawn in. That would identify where the leak is.
  10. Feb 6, 2009 at 6:56 AM
    98tacoma27
    Ben
    Not Beech Creek
    Sorry, that made me lol for some reason
    Get the full list of codes, as sometimes one code is a result of another. Denso is the OEM sensor for Yotas. I too have heard of Boschs being hit or miss.
  11. Feb 6, 2009 at 7:57 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    yeah...chris never mentioned he was bill's cousin
  12. Feb 6, 2009 at 8:02 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :mad:
  13. Feb 6, 2009 at 8:26 AM
    98tacoma27
    Ben
    Not Beech Creek
  14. Feb 6, 2009 at 1:49 PM
    The_Hodge
    SC
    i was thinking more of clinton, not firemarshall....but that works too
  15. Feb 6, 2009 at 4:29 PM
    sbvaughn88
    Grove City, OH
    4dr Sr5 V6 TRD
    OK I have the correct info now- I went back to advance and had the scan done again...Now the only code showing is P1135. I had the guy clear it and the light went off for a second then came back almost right away. I think there may have been two problems and now the rear o2 sensor is fixed there is another issue. I am wanting to resolve this but not sure what could be wrong with that code?? Can anyone offer any suggestions about what that code usually means?? is it the A/F sensor?? Thanks alot for all of the replies....This forum is very helpful for those who dont want to bend over and take it to the dealership.
  16. Feb 6, 2009 at 4:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    P1135 = air/feul sensor-heater circut.
  17. Feb 6, 2009 at 4:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its the O2 sensor before the cats.
  18. Feb 6, 2009 at 4:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Before replaceing the sensor, make sure its connected propperly.
  19. Feb 6, 2009 at 4:57 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    You beat me to it Chris! Check the resistance on the 02 sensor(s) in question with a ohm meter to further diagnose the situation. You should be able to get the specs from the FSM.
  20. Feb 6, 2009 at 5:04 PM
    SC4333
    Grant
    FL
