Excessive Power Steering Noise
Discussion in 'Technical Chat' started by PcBuilder14, Feb 1, 2013.
  1. Feb 1, 2013 at 10:41 PM
    PcBuilder14
    PcBuilder14 [OP] Well-Known Member
    Brent
    Southern New Mexico
    2018 Tacoma TRD Off Road 4x4
    Here for the past few weeks or so my power steering makes a lot more noise than normal it seems.
    When the vehicle warms up or when it's warm outside it seems to quite down. Fluid levels are good also. It didn't seem to start doing it until I got the timing belt and water pump replaced....:confused:
    Don't know if this helps, there is also a odd noise that sound like maybe the bearings for the pulley are going out? I'm not sure, but you can't here it on the video.
    http://youtu.be/Cx6PMxfcl70
  2. Feb 1, 2013 at 10:59 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Low fluid?
  3. Feb 1, 2013 at 11:00 PM
    PcBuilder14
    Brent
    Southern New Mexico
    That was my first thought, but it's always between the cold and hot level...
  4. Feb 1, 2013 at 11:03 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    Here's a trick to locating noises on engines.
    Find a metal rod. Run engine. Touch the rod to where you think the noise is coming from. Touch the other side to your ear. Listen for the noise.
  5. Feb 1, 2013 at 11:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Belt torqued right? Any leaks anywhere on the pump and rack? Pulley tight?
  6. Feb 1, 2013 at 11:07 PM
    PcBuilder14
    Brent
    Southern New Mexico
    No leaks that I can see, if it is leaking it's not even enough to have ever made it to the ground. The underside of the truck doesn't have a drop of any fluid on it.
    As for the pulley being tight, it was so tight that I could barely get a good enough look at the belt to see if it was worn. Could it be too tight?
  7. Feb 1, 2013 at 11:07 PM
    RMAN808
    RMAN808 S)(AKALO)(AWAII
    Reid
    Pearl City, Hawaii
    '17 TRD OR 4X4 Quicksand
    That's exactly what I constantly experience with my 99 :eek:
    Idk what it is but I also get vibes + that humming when turning.
  8. Feb 1, 2013 at 11:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Pulley could be too tight or the bearing shot too.
    Or the rack bushings..
  9. Feb 1, 2013 at 11:21 PM
    PcBuilder14
    Brent
    Southern New Mexico
    Ugh... I really hope it's jut too tight...
  10. Feb 1, 2013 at 11:26 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I'd take it to a shop and have em listen :notsure:
  11. Feb 1, 2013 at 11:28 PM
    PcBuilder14
    Brent
    Southern New Mexico
    I'll probably take it to Toyota tomorrow and see what they say then... This will be my first dealing with Toyota up here. Hopefully they're as good as back home!
  12. Feb 1, 2013 at 11:31 PM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    My power steering went on my '10 honda, my engine was howling like a dog. Freaking annoying, how you get it fixed :thumbsup: .
  13. Feb 2, 2013 at 6:55 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Vacuum test the system to check for air in it. Bleed/flush with new fluid. If the noise is still there, your pump is shot.
  14. Feb 2, 2013 at 7:57 AM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    I'm not sure how the pumps have changed, but on my old 96 there was a little seen that would help filter stuff out of the pump and that got clogged up and started making that noise.
  15. Feb 2, 2013 at 8:15 AM
    goomba
    goomba It is a Fluid Situation
    Josh
    San Antonio Fl
    96 White Ex. Cab Tacoma TRD 4X4
    3" lift Up front(Donahoe Racing ext. travel coil overs, Camburg UCA's), 1.5-2" lift in the back(aal and some billy 10" stroke short bodies), Bushwhacker Cut-Out fender flairs, 16"x10" Procomp Street locks, and 305/70 Procomp X-Terrains.
    This^^^^^ Check my post in What have you done to your tacoma today
  16. Feb 2, 2013 at 9:58 AM
    PcBuilder14
    Brent
    Southern New Mexico
    Hmm, ok. How do I go about removing fluid to get access to the filter?
  17. Feb 10, 2013 at 7:21 AM
    goomba
    Josh
    San Antonio Fl
    I took off the hose on the outside of the resi and drained from there. Then took off pump and then took off resi.
    I am going to make a movie of what to do to fix it. I have an extra one sitting in the garage.
  18. Feb 10, 2013 at 9:48 AM
    PcBuilder14
    Brent
    Southern New Mexico
    Awesome, thanks!
  19. Feb 10, 2013 at 2:57 PM
    goomba
    Josh
    San Antonio Fl
  20. Feb 10, 2013 at 3:14 PM
    PcBuilder14
    Brent
    Southern New Mexico
