Lifting problem
Discussion in 'Technical Chat' started by NickH92, Mar 6, 2013.
  1. Mar 6, 2013 at 6:14 PM
    NickH92
    NickH92 [OP] Member
    Nick
    Tuscaloosa
    '11 Tacoma Trd Sport Pkg. 4x4
    10% window tint all around. 6000k HID headlights. Blacked out Emblems.
    I'm in the process of installing a 2.5" spacer lift on my truck and when I bolt the top part of the shock the bottom part doesnt line up with my strut bolt hole. Is there any way to spin the yellow portion of the shock to line up?
  2. Mar 6, 2013 at 7:13 PM
    BradyT88
    BradyT88 Well-Known Member
    I can't remember for sure but I thought it free spun already... Maybe you just need to give it a little more force to turn it.
  3. Mar 10, 2013 at 4:50 PM
    BamaToy1997
    Bill
    Navarre, FL
    It has tension on it, but it can turn.
  4. Mar 10, 2013 at 4:53 PM
    KalamaKid
    KalamaKid Well-Known Member
    Jason
    Oregon
    same shit as everyone else
    Pic of the whole assembly? Might need to be lined up a little.
  5. Mar 16, 2013 at 11:10 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    with an assembled strut it is hard to turn, especially after all the preloading from spacer. now that im thinking about it, if your lower collar is welded to the shock body, maybe not as both it and the top-plate are indexed to the coil. if that is the case it will indeed be very very hard to turn. . . . . .right?
    my only experience with this was on my 5100s, where the lower collar can spin on the shock body. it was difficult to turn, but not too hard with a spud in the lower eye and hand pressure on the coil
