-   -   Outside air temp sensor location for thermometer (http://www.tacomaworld.com/forum/technical-chat/267145-outside-air-temp-sensor-location-thermometer.html)
Popster 03-07-2013 11:18 PM
I want to add an inside/outside thermometer to my 07 standard Tacoma. I purchased a battery powered in/out thermometer and ran the outside sensor under the front fender and mounted it on the bracket for the front wheel well liner. It is behind the bumper, but close to the supporting bracket.
When I stop at a light, the engine heat raises the displayed temperature.
Does anyone know where the sensor should be located.
I will have to splice the wire if it needs to go any further. I'm guessing that a careful splice will be possible- that is to say that the length of the wire should not affect to reading.
Any help will be appreciated.
Tacoma Mike 03-08-2013 04:17 AM
Factory location is in the center support in front of the condenser/rad.
Factory units have a buffer/delay because of this issue. Your unit is instant and will reflect the temp spikes.
T@co_Pr3runn3r 03-08-2013 04:31 AM
I ran the temp sensor for my Gentex341 auto dimming/compass/temp/homelink/maplight rr view mirror to the center support of the radiator right behind the bumper skin/license plate. It is out of the direct wind flow but not close enough to the radiator/condensor to get any temp spike action when stopped.
127.0.0.1 03-08-2013 05:31 AM
does it have a/c ?
if so, scangauge should be able to fetch outside air temp
otherwise temp is picked up at foglight level in the open
part of the bumper near the plate
Popster 03-08-2013 04:53 PM
Originally Posted by 127.0.0.1 (Post 6556178)
does it have a/c ?
Yes, it does have A/C. I emailed scangauge to confirm that it could monitor outside air temp.
Thanks to all for the help!
grandpapacker 05-08-2013 04:29 PM
Mount sensor in wheel well
Just move the your sensor into your front wheel well away from any heat source.You must have it located in the bumper and close to your radiator.\\
Popster 05-08-2013 09:53 PM
Thanks to all for the the help! I successfully installed a Cipa 36500 mirror with temp and compass. Took about an hour. I put the temp sensor on the bracket in front of the ac condenser. Works fine.
