Sudden HUGE decreases in MPG, 14.5 to 7.5
Discussion in 'Technical Chat' started by nagorb, Mar 19, 2013.
  1. Mar 19, 2013 at 9:22 PM
    nagorb
    nagorb [OP] Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I filled up two days ago and everything seemed fine, then when I was coming home from work monday I realized I had already gone through a 1/4 tank, this morning I dropped down to almost 1/2 on my way to work, about 13 miles.
    My first thought was that someone was stealing gas, but I stayed at my girls place last night and was at mine before that, also I watched it go down all the way to work. I've been getting mid to high 14 mpg since I've owned the truck, about a year. Now it’s around the 7.5-8mpgs so a HUGE decrease.
    It's not the tires or winter gas, there has been little fluctuation since I put the tires on and the onset of winter gas, if it was either of those it would have happened long ago, I have done nothing to the truck in the last month or two. I have in the last six months changed the motor oil, diff oil, greased the joints, new air filter, cleaned the MAF and throttle body and replaced the spark plugs with ones form the dealer. I have no codes or pending codes. Not towing anything, nothing has changed in the last month or few days.
    Any ideas? I've found a few suggestions around the web but mostly people saying it's winter gas or large aggressive tires, which is not the case since it hasn't been an issue for quite some time and suddenly dropped to almost half.
    Thanks.
  2. Mar 19, 2013 at 9:24 PM
    RiverBoyTRD
    RiverBoyTRD Well-Known Member
    Jonathan
    San Antonio
    05 TRD OR
    2 Hellas, 3 inch, spiders, grill guard, 285's, BHLM etc.
    clogged cat
  3. Mar 19, 2013 at 9:36 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    How would I check? have to take it off?
    It's bad but not very in a double cab, at least from what I've seen in the firs gen forum.
    Wish I was getting 20:mad:
    I was planning on changing the fuel filter in the near future, I doubt it has been changed. I would think if there was a vacuum leak a coed would show though?
  4. Mar 19, 2013 at 9:40 PM
    jberry813
    Jason
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    ^This. Same thing happened to my truck, but i was closer to 5-6 mpg.
    Backpressure test. Basically you remove the front o2 sensor and replace it with a backpressure test gauge. If the cats are clogged, bp will be high.
  5. Mar 19, 2013 at 9:45 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Did you gap the plugs? Don't know much at all about the 1st gens. My plugs were close from the dealer but not right on, one was actually almost touching. Idk? Wouldn't explain the crappy mileage all of a sudden. Good luck .
    Brett
  6. Mar 19, 2013 at 9:46 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Did your rig feel like it was under power also?
    Brett
  7. Mar 19, 2013 at 9:46 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    I'll have to give it a try, I'll either pick one up or use my buddies. Hope it's that simple and not something all fucked.
  8. Mar 19, 2013 at 9:48 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    I did, they were fine though.
    Mine doesn't at all seems to drive just the same.
  9. Mar 20, 2013 at 6:57 AM
    BamaToy1997
    Bill
    Navarre, FL
    I agree with this! DANG I remember that thread. We were chasing all sorts of potential possilble causes with that truck, if it is the one I remember.
  10. Mar 20, 2013 at 9:07 AM
    jberry813
    Jason
    Lake Tahoe
    2012 DCSB Sport
    Yessir! That was the thread. A month endeavor to find this:
    1072B772-A5CD-4E0B-AD77-59EF70BC042C-612_e2976f385713752a9458616917ee0e5a38c90783.jpg
  11. Mar 20, 2013 at 9:28 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    ^^^ clogged cat is top suspect
    if cat is not clogged,
    if tailpipe has black soot it is running too rich, and could be ecu malfunction
    or a/f sensor malfunction but not throwing a code
  12. Mar 20, 2013 at 9:41 AM
    rockgecko03
    rockgecko03 Well-Known Member
    Ben
    Rockwall, TX
    1999 Tacoma - Perpetual Project
    if not a clogged cat - leaking fuel line?
  13. Mar 20, 2013 at 1:08 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Low tire pressures (obvious),
    dragging brakes (should cause friction heat),
    bad sensor causing ECM to increase fuel (many sensors to check)
  14. Mar 20, 2013 at 2:22 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    on my 99 5vzfe
    when my a/f was on the fritz not yet blowing a code
    and at the same time my TPS was about to go bad (also not throwing a code)
    my tailpipe was sooty...replaced a/f when it finally shat p1135 at me and
    fixed tps and blam, clean pipe again
  15. Mar 28, 2013 at 8:02 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Sorry for the lack of update been busy at work.
    So my MPGs went back up to 13.5ish, still low but not nearly as bad. I figured my buddie would have something to test the back pressure, dude usually does. Rather then buying one I figure I could just take the cat off and run through a tank. Still haven't had time to do it though, not sure how loud it will be, I was thinking of fabbing up a through pipe.
  16. Mar 28, 2013 at 8:09 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    Another way to check your cat is by heat. Get a laser temp gauge. If the cat is hotter than the rest of your exhaust than its bad. They will glow cherry red sometimes when they are clogged. But a laser temp would tell you if there is a big difference.
  17. Mar 28, 2013 at 8:13 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    Thanks! I've got a few of them at work, I'll check tomorrow.
  18. Mar 30, 2013 at 7:52 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    I checked it yesterday, I left the numbers at the shop but it was hotter before the cat, the cat and pipe after were cooler. I think it was 450 before the cat and 350 at the cat and after.
  19. Mar 30, 2013 at 9:36 PM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    This sounds like a cat issue to me too.
    A good indication is really poor mpg and loss of power.
    The power loss symptom is sometimes hard to determine.
    If you have a light truck with good hp it may not show up easily.
    One way to determine real power loss is to load the truck up, and hit a long steep grade. If u are depressing the gas and downshifting way too much, this is strike one.
    The easy no high tech tool test before pulling cat is to remove the o2 sensor before the cat, tie it up, and hit the hill again. If u run right up the hill, strike 2.
    Final test, pull the exhaust and look at the inside! It usually shows broken or chunked up pieces. Strike 3.
    Time to post on TW for a used cat, hit the junkyard, or buy a new high proformance cat.
    Good luck.
  20. Mar 30, 2013 at 9:42 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    As far as I can tell I havent noticed any loss in power, but I'll give it a try tomorrow.
    thanks
