-   -   ABS SKID/ECU Computer Replacement (http://www.tacomaworld.com/forum/technical-chat/269151-abs-skid-ecu-computer-replacement.html)
jonathan 03-20-2013 11:38 AM
Hey guys, so my ABS and traction control lights were lit.
I did all the trouble shooting I could do and then brought it in to the dealer.
They said I need a $3050.47 "SKID ECU/BRAKE ACTUATOR COMPUTER"
Part #44050-04100
Anyone have to replace this before?
I found a few $150 ABS computers on ebay but I am not sure if they are a scam/wrong part or not. I also found a guy that will sell me a remanufactured one for $350
Any info would be awesome, THANKS!
-jon
cjimenRR 03-20-2013 11:44 AM
If you look on the abs actuator itself you should see the computer is bolted onto the actuator. Toyota doesn't sell the computer on its own hence the hefty price tag. Check where all the electrical connectors go on the computer there should be a part number, take that number to your local wrecking yards and buy just the ecu
jonathan 03-20-2013 12:00 PM
Awesome thanks for the super fast response!
tacopa 03-31-2013 07:50 AM
ABS & Trac lights
I just had mine replaced by the dealer less than a month ago and the lights have come back on twice. I took it back in and since they were not able to recreate it they told me there is nothing they could do. The truck only has 6,900 miles on it. The ABS & Trac lights would come on at random times(every several hundred to 1,000 miles. If I stopped the truck and shut it off for a few seconds, sometime it would go off(but not always). I spoke to the service coordinator at the dealer and he is setting up an appointment to have a Toyota Field Tech check it out. I have had multiple issues with this truck since day one and it is really starting to get old having to take so much time off of work to bring it into the dealer. The reason I buy new Toyotas is so I do not have these kind of inconveniences. I'll keep you posted on what they find.
tacopa 03-31-2013 07:53 AM
By the way, when I picked up the truck I had to sign their warranty paper for the covered repairs(replacement of brake actuator & driver's side door motor) and the total was around $2,500 for everything.
jonathan 03-31-2013 02:08 PM
Yikes! On such a new truck? That stinks.
Keep me posted. I still haven't done anything with my issue yet. I am just driving around trying not to slam on the brakes haha.
Erik 06-27-2013 09:43 AM
I have an issue where I have most likely burned something out. I did an ATRAC hack mod and one day wheeling with bigger tires, the ABS/VSC/limited slip shit the bed. I got the codes for it and it's saying that I have a drivers/rear wheel speed sensor malfunction (could also be the circuit) and a decelerator sensor malfunction (could also be the circuit). The two things that those codes have in common are the brake actuator (skid control ecu) could be damaged.
I tested the wheel sensors and they all are getting power except the drivers/rear. Tonight I will test the decel sensor under the drivers seat (if anyone can tell me how to get to it, I would be grateful to save an hour of work). If the decel sensor is not getting power, I think the next thing to do is test the skid control ecu. Any ideas how do I do that?
I just need to pass inspection so I will unplug the damn abs light bulbs before I spend 2500 to get a new computer. I liked wheeling with the atrac hack though so I want to get it working again if I can.
jonathan 07-03-2013 11:37 AM
I finally found the ECU on ebay, has anyone changed this out before?
