Rear Diff Oil and Red Fluid on driveshaft
Discussion in 'Technical Chat' started by NorCalTRD, Mar 23, 2013.
  1. Mar 23, 2013 at 9:52 PM
    NorCalTRD
    NorCalTRD [OP] Well-Known Member
    Northern California
    '06 Indigo Ink DCLB TRD Sport V6
    40% Front Tint, Viper 5704 Alarm, Steel Cable Dog Tie, Super Sexy Driver Mod
  2. Mar 25, 2013 at 8:59 PM
    NorCalTRD
    Northern California
    Pretty quiet in here huh?
  3. Mar 25, 2013 at 9:04 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I have that same drop
  4. Mar 26, 2013 at 5:29 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Read the bottle on the oil jug to make sure it's got the friction modifier required for a limited slip differential and not just compatable with a limited slip differential. A lot of gear oils say limited slip compatable but that means you still need to add the friction modifier to make the LSD function properly.
    As far as the fluid, I think I'd be looking at changing that seal if I were you.
  5. Mar 26, 2013 at 6:03 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I moded 1999 Taco so much it had turned to Land Cruiser
    RED fluid is your automatic transmission so you need to change seal and make sure transmission fluid level is correct.
  6. Mar 26, 2013 at 10:21 PM
    NorCalTRD
    Northern California
    Thanks everyone, I went ahead and changed the diff out with some new fluid and additive. I replaced the leaky seal and will be compiling a DIY on it for TW. :)
  7. Mar 26, 2013 at 10:26 PM
    anthony250f
    Anthony
    San Diego, CA
    Was it hard ? I havent bothered because its so minimal
  8. Mar 28, 2013 at 6:44 PM
    NorCalTRD
    Northern California
    Easy as pie, and it may seem like an insignificant leak but mine was at least 1/2-3/4 quart low when I topped up after fixing it.
    Id say do it, and if you need some pointers check my DIY write up.
    Should take 20 mins and about $20 for the seal and a quart of Toyota WS ATF fluid.
    Ive been checking my housing everyday since doing it and no more leak! :)
