-   -   95.5 Tacoma - Hard / notchy shifting solved (http://www.tacomaworld.com/forum/technical-chat/270677-95-5-tacoma-hard-notchy-shifting-solved.html)
flatblack 03-29-2013 04:11 PM
Hey!
I wanted to post this in hopes that it might help someone out; and keep them from needlessly blowing all sorts of ridiculous money on a new transmission or something
I recently bought a 1995.5 Tacoma 3.4 5-speed with 197k on it
When I bought it, it was a little tough going into First gear; but, it was about 10 degrees out the day I test drove it, so, it didn't strike me as a red-flag
Over a short period of time, it would completely lock me out, and, if from a stop, I could only get into 5th or Reverse - and once I did (keeping the clutch pedal down the whole time), it would then let me into First
I replaced the shifter seat and socket with Marlin Crawler parts; this made absolutely no change
I drained the existing transmission fluid (looked clean) and filled with Redline MT-90; absolutely no change
Checked for Master and Slave cylinder leaks or air in the system, everything was fine there
Also had a slight pedal adjustment done, despite the Pedal not being soft and engaging in the proper spot; all that... no change
Finally had a mechanic look at it, who seemed very confident my synchros were shot
I couldn't accept this, though; because, it seemed more like a clutch issue to me
Also, First isn't a synchronised gear, and that's where most of my grief was coming from
But, strangely, the clutch would absolutely never slip or give any other indications of being burnt;
One day, I put it into Reverse; and with the clutch still disengaged and the E-Brake on, the truck lurched back and inch or two
So, after the longest time, I finally decided it was most likely an issue of the clutch not fully disengaging - and dismissed the mechanic who told me it was the synchros
I probably could have figured this out way quicker if I jacked the truck up and saw if the tires spun at all with the truck in gear and the Clutch Pedal pushed all the way down
So, I ordered a 1,200 lbs Marlin Crawler Clutch Kit and Flywheel
Just got the job done (I didn't personally do it)
The Clutch Cover and Clutch Disc that were in there are so new, they still have machine marks on them; the Throw-out looked new, too
HOWEVER! Whatever hack-job did the last clutch job put the Clutch Disc in backwards! (The engraving "T/M Side" (Transmission Side) was facing the engine)
The Flywheel looked like absolute garbage; was blatantly not resurfaced when the last job was done
And, the Pilot Bearing used was junk; and no longer spun properly, but was real gritty and such
Been driving for about a day with the 1,200 lbs Marlin Crawler Clutch Kit and Flywheel;
No more problems! Am very happy with it
I know this is a pretty unique situation; but, hopefully someone finds something useful in it and saves them some money
Olafson 11-16-2014 08:28 AM
I just bought a 97 that does similar clutch misbehavior. I have to push the clutch HARD to the floor or it grinds going into some gears or is otherwise difficult to get into gear. The other thing I do not like about my new truck is that the clutch seems to engage about a 1/2 inch from the floor. Makes it tricky shifting with boots on! Maybe I'm just used to my old Ranger and Subaru... Is there an adjustment I can make to the hydraulic clutch or did a previous clutch replacement get botched like on yours? B
