-   -   Castrol Hypoy C 80w-90? (http://www.tacomaworld.com/forum/technical-chat/271992-castrol-hypoy-c-80w-90-a.html)
Mossy 04-06-2013 02:30 PM
Anybody using it? I have a 97 sr5. Any opinions or suggestions of something better?
Mossy 04-07-2013 05:45 PM
Anyone?
Mossy 04-15-2013 03:23 PM
Bump
azreb 04-16-2013 07:35 PM
From what I have read on the web it sounds like an acceptable lube for differentials. The advertisements say it is intended for manual transmissions, also. However, it is a GL-5 lube. From previous research, I decided against using GL-5 gear oil in my manual transmissions. The sources I saw (sorry--no links. I did this research a year or so ago) said that the additives that make the GL-5 work well in differentials contain chemicals that are corrosive to copper and brass. The syncros in manual transmissions are brass.
YMMV. I have seen other brands of GL-5 gear lube with manual transmissions mentioned in the application notes, but I choose to not take any chances. I found a synthetic GL-4 lube that has worked well for me.
KenLyns 04-16-2013 07:38 PM
FYI Toyota owner's manual specifies GL5 for manual transmissions for all years Tacos.
Can you even find GL4 easily in auto parts stores?
azreb 04-17-2013 01:37 PM
The manual for mine recommends GL-4 or GL-5. For the reasons I mentioned above I will stick with the GL-4. I found Redline MT90 GL-4 on the web.
BUZZCUT 04-17-2013 05:53 PM
Amsoil Severe Gear 75w-90
Jetman1979 04-17-2013 05:59 PM
castrol makes some good lubes. I have used there engine oil for years I say go for it.
