Change thermostat?
Discussion in 'Technical Chat' started by iJDub, May 21, 2013.
  1. May 21, 2013 at 3:47 PM
    iJDub
    iJDub [OP] Well-Known Member
    I'm doing my coolant swap at 120k. Should I go ahead and swap thermostat out now? Or just wait till it goes?
  2. May 21, 2013 at 6:25 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    It's probably not a huge priority if it works. Soon you will be needing a timing belt and water pump, and it's a good time to change the thermostat.
  3. May 23, 2013 at 7:56 PM
    koco
    Bay Area Ca.
    '01 Taco
    2nd gen.? This is key information. Disregard what I said about the timing belt then. lol
  4. May 24, 2013 at 1:58 PM
    iJDub
    Lol got it. I ended up not replacing it. I figure ill do it when I need to.
