Maintenance Light has two factor switch?
Discussion in 'Technical Chat' started by Frogsauce, May 23, 2013.
  1. May 23, 2013 at 9:11 AM
    Frogsauce
    Frogsauce [OP] Well-Known Member
    Chesapeake Bay
    16 TRD Offroad
    Hey guys, no trouble, already changed oils and turned the light off... but...
    Just glossing over the 2009 Tacoma manual and noticed it says this:
    This seems to imply there is some kind of difference in how it determines when oil should be changed. I thought it went off mileage, but could it also be going by something else? Revolutions maybe?
  2. May 23, 2013 at 9:17 AM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    I think it's all mileage based.
    Mine comes on flashing when I start truck around 4500 miles after oil change, then goes away after one minute or so. If I go over 5000 miles then It stays on constantly.
  3. May 23, 2013 at 9:21 AM
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Flashes on startup at 4500 miles, then stays on while running at 5000
  4. May 23, 2013 at 9:23 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    ^^this
    Just mileage, micro computers are cool things.
  5. May 23, 2013 at 9:23 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    x2, it's 100% mileage based. It's just a dummy light, it doesn't 'determine' anything, just based on how many miles you drive.
  6. May 23, 2013 at 9:34 AM
    Sandman614
    Tim
    '06 SR5 Off Road
    It would be nice if it "knew" i was using synthetic and change @10,000mi
  7. May 23, 2013 at 9:36 AM
    Frogsauce
    Chesapeake Bay
    16 TRD Offroad
    Alright thanks for the confirmation. I figured it wasn't intuitive, but wasn't sure why it had the odd wording in the manual. My only thought was revolutions.
    I also read somewhere on here how to reset it, but I don't think it mentioned that each of those little dashes that display when holding the reset switch is an increment of 1000 miles.
    Not sure if that's true, but if so, that means you could set it at 3k or 4k if you wanted? (I always just check the oil itself, some of these synthetics last longer than 5k)
  8. May 23, 2013 at 9:39 AM
    Pugga
    Massachusetts
    My Ultra-gauge is programmed for 7,500 mile intervals :)
