-   -   4wd dash light blinking , 4wd not engaging (http://www.tacomaworld.com/forum/technical-chat/285443-4wd-dash-light-blinking-4wd-not-engaging.html)
mxxdude 07-07-2013 02:25 PM
My 4x4 in my 2006 Tacoma was working fine the other day, today I got in the truck and the 4x4 light on the dash was blinking in 2wd , tried to engage it in every way didnt work, when I put it in 4 Lo no beep or 4lo light , and the dash light is constantly flashing .
No sounds come from the truck when I try anything
Checked the fuse by the left knee and replaced it and now I'm stuck truck has 62xxx miles
Bsheriff11 07-07-2013 03:29 PM
Check the 4X4 actuator black box located behind the transfer case, a lot of people report moisture/grime get inside. The fix is to remove the cover, clean it out, and solder the connections together as they are just free inside the actuator. There is a guide here somewhere.
mxxdude 07-07-2013 08:48 PM
Thanks I saw the black box the actual electrical connection was dirty so I cleaned it out hoping it would fix it but no go Tommorrow ill have to take it off
Bsheriff11 07-08-2013 09:30 AM
Yea take it off and clean the inside really well, then solder those electrical connections on if you have the means, then seal the actuator back up to reduce dirt getting back in there.
Bsheriff11 07-11-2013 07:47 PM
Update OP?
mxxdude 07-14-2013 01:06 PM
I took off the entire a.d.d when I was changing my diff fluids and all the connections look good there was alot of water in it so I though that had to be it. Unfortuantly it wasn't and my dash light is still blinking and nothing is engaging
mxxdude 07-14-2013 03:57 PM
Originally Posted by PSU Taco85 (Post 7161261)
Hmm, check the voltage readings and post them up ill take a look
From the plug that connects to the outside of the actuator or the actuator itself
Sje1124 07-26-2013 04:52 AM
Mine just started doing this today
mxxdude 07-29-2013 01:22 PM
I'm back from AT today so hopefully ill be able to diagnos this finally Im goin to start with the transaxle actuator
erockstacoma 07-29-2013 04:07 PM
Apparently the design of the tacoma actuator is defective like mine is. My 2005 tacoma w/55000k is stuck in 4wd hi with light flashing 4lo. dealer wants $1600 to fix it. already spent $1700 on defective a/c. Dont think I will ever buy another.
mxxdude 07-29-2013 08:09 PM
It's annoying because the light is always blinking in 2hi nothing happens at all when I flip the switch to 4hi or 4lo
I'm going to check the connections to the t case actuator and after that I don't know what the F else to do
Sje1124 07-29-2013 08:28 PM
Originally Posted by PSU Taco85 (Post 7228357)
the t-case actuator is a POS. It's cheaper to just swap in an FJ transfer case than to buy a new tacoma actuator.
Where did you get the FJ transfer case from?
Sje1124 07-29-2013 09:30 PM
Originally Posted by PSU Taco85 (Post 7229057)
a guy down the street from me was selling it since he got rid of his truck and was parting it out. They are readily available in the junkyards though
and ebay, just did this search
http://www.ebay.com/itm/TRANSFER-CAS...36e832&vxp=mtr
Was it a hard conversion?
Sje1124 07-29-2013 09:51 PM
Originally Posted by PSU Taco85 (Post 7229309)
Took a full weekend, but not that bad really.
So not to bad for someone with mechanical skills? Because I have limited mechanical skills lol. Id prob have to pay a shop to install it for me
Sje1124 07-29-2013 10:13 PM
Originally Posted by PSU Taco85 (Post 7229433)
If you have a manual transmission it's alot easier but for an auto you will have to do some cutting and rewelding of the transfer case shifter to get it to fit. Also, hope you wouldn't mind cutting a hole in the floor I doubt you would find a shop that would want to do that, it's not as straightforward as your typical requests :D
http://www.tacomaworld.com/gallery/d...liveFouvCZ.jpg
https://fbcdn-sphotos-c-a.akamaihd.n...90544396_n.jpg
I dont mind cutting on the truck at all. Now welding...not my forte. Lol
CASTRATE 07-30-2013 03:10 PM
Where would one go to purchase an fj t case? I want to get one eventually. The stupid little dial thingy drives me bonkers
mxxdude 08-23-2013 02:29 PM
IF anyone still has this problem it turns out it was the elecrical solenoid in the actuator, thats was fried even though it was still firmly connected , just in case anyone was wondering, took it to toyota and since my friend is a lot attendant it was 600 with parts and labor. not as bad as i though
double dee 12-07-2013 08:25 AM
Does anybody know if the actuator is covered under the 5 year 60k powertrain warranty?
