Compressor problem?
Discussion in 'Technical Chat' started by steve390, Sep 15, 2014.
  1. Sep 15, 2014 at 3:11 PM
    steve390
    steve390 [OP] New Member
    Steve
    Southern California
    Prerunner SR5
    K&N Performance Intake Spyder Halo Headlights
    I overcharged my ac system a few months ago because I thought it was low since it was blowing only barely cool air. Got the pressure back to where it should be. But now in idle the compressor cycles off and on constantly a lot of the time and won't blow cool air unless the truck is moving. Also, now the blower ceases to turn on unless its on high. Getting the feeling that a new compressor will be in my future. Checked the fuses and they are good.
  2. Sep 15, 2014 at 7:54 PM
    G17GUY
    G17GUY Well-Known Member
    Modesto Ca
    tacoma
    spining hub caps chrome stick-on trim new car smell air freshiner stering wheel suicide knob nut sack on hitch back window curtain
    Start over. Pull a vacuum, put 22oz of 134a and see if that works. If not you have other issues.
  3. Sep 20, 2014 at 8:27 AM
    G17GUY
    Modesto Ca
    tacoma
    Did you try this yet?
  4. Sep 21, 2014 at 11:24 AM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    That is unrelated to your compressor problem. You have a bad blower motor resistor.... That is an easy 15/20 minute fix to change out.
