Oil capacity (4.0L V6)
Discussion in 'Technical Chat' started by bigmooze, Aug 4, 2009.
  1. Aug 4, 2009 at 5:27 PM
    bigmooze
    bigmooze [OP] Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Can someone clarify how much oil I should have put in my truck at the last oil change?
    I'm using 5W30 (not that it affects capacity). My dealership tech says 5.6L, the owner's manual says 5.2L (with filter), and I could only find torque specs for the truck in the FSM.
  2. Aug 4, 2009 at 5:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    5.5 quarts. With a filter change.
    b_r_o and Stryker420 like this.
  3. Aug 4, 2009 at 5:31 PM
    bigmooze
    Richard
    Belle River, ON
    Geez Chris, you're gonna make me convert that myself??? Hahaha, thanks man.
    BTW: just for quick reference for others in the future, 5.5 qts = 5.2 L
  4. Aug 4, 2009 at 5:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL! Soorry....I dont do conversions. :eek:
    TacoNorth2010 likes this.
  5. Oct 29, 2013 at 4:10 AM
    tiercel
    tiercel New Member
    Don
    Seattle
    2011 4WD w/ HD towing package
    Rear suspension airbags
    Did my 1st oil change today (previous 2 years came with the new truck purchase). I expected to have to put in the 5.5 qts with a filter change, and I THOUGHT all the oil was drained out, but it took only about 4 qts before hitting the FULL mark on the dipstick. I left the filler cap off while draining but hadn't yet removed the filter - maybe that needs to happen first? Thanks for any pointers!
  6. Oct 29, 2013 at 5:30 AM
    SpacemanSpiff
    SpacemanSpiff Well-Known Member
    James
    08 TRD Off-road
    You didn't mistakenly drain the tranny, did you? Also, the dipstick isn't worth a shit.
  7. Oct 29, 2013 at 2:13 PM
    tiercel
    tiercel New Member
    Don
    Seattle
    Thanks for the reply. Definitely the crankcase not the tranny!
    I was wondering about the dipstick. It always shows a higher level on one side of the blade than the other, apparently where it rubs against the tube as you slide it in and out. And you have to let things quiet down a few minutes after running the engine before trying to read it. But I was getting consistent readings on ONE side as I added oil so I think it can be accurate if you know how to use it. Have other people reported issues with this?
    06_Kukui_Taco likes this.
  8. Oct 30, 2013 at 3:47 AM
    bigmooze
    Richard
    Belle River, ON
    I just drain the sump, replace the filter and pour in 5.2L of fresh oil. Some people, including myself, struggle with getting a decent reading on the dipstick. I always seem to drain out about 4.8 to 5L of old oil at each change and that's been the case since I bought the truck.
  9. Oct 30, 2013 at 4:00 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    I find it easier to pour some oil in and wait just a few min to let it drain down into the pan. I usually get the best reading that way. As far as tiercel only having to add 4 qts back there seems to be problem there. You did pull the skid plate to get to the oil pan? Definately need to figure that out.
  10. Oct 30, 2013 at 4:07 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    not so low, not so slow 2006 6 lug
    stockish
    not needed unless hes got aftermarket skids :notsure:
    either way.
    4.0 V6 should take 5.5 to a hair under 5.7 quarts.
  11. Oct 30, 2013 at 4:29 AM
    TACO TX
    Kelly
    Denison ,Texas
    My bad, us first gens have to pull the skids to change ours.
  12. Sep 28, 2017 at 8:14 PM
    WhiteNight
    WhiteNight Well-Known Member
    PDX
    13 DCLB SPORT
    Dynamat, Rigid E series 30", Rigid SR2 combo/Rigid grill, Redline elite hood struts, Clear Bra all over
    I did this one time on accident and well I was an idiot and ruined my tranny so I traded in my 4Runner and got my new taco
    brother.earth likes this.
  13. Mar 12, 2021 at 8:59 PM
    jtaco11
    jtaco11 Well-Known Member
    Ive been using 5 qt jug since day 1. Hassle buying extra qt use half/save. 5 qt jug in drain into older jug use zip lock bag catch oil from oil. Also have fumoto value never a drop on floor.
  14. Mar 12, 2021 at 9:00 PM
    Bishop84
    Bishop84 Well-Known Member
    Post is from 2009 haha. 5qt is agreed on for all 4.0's
  15. Mar 12, 2021 at 9:04 PM
    jtaco11
    I was looking up my 2019 rav4 oil capacity 4.8 qt then thought about my 05 taco capacity 5.5 but I've never gone over 5. Hate having buy the extra qt
  16. Mar 12, 2021 at 9:08 PM
    b_r_o
    b_r_o Beef jerky time
    Alex
    WA
    2015 DCLB
    The area between the dots is called the safe zone for a reason :thumbsup:
  17. Mar 12, 2021 at 9:41 PM
    jtaco11
    Yeah you would think but the read on dip stick is all over the place.
  18. Mar 12, 2021 at 9:47 PM
    b_r_o
    Alex
    WA
    2015 DCLB
    Pull it out, leave it to the side while you're changing the oil. After you fill it with about 5 qts and run it, let it sit for a few minutes before inserting the stick.
    Only stick it once or twice, after that the oil gets pulled up into the dipstick tube and makes the stick hard to read
