Changing out coil packs for a distributor
Discussion in 'Technical Chat' started by Maxola89, Sep 23, 2009.
  1. Sep 23, 2009 at 6:13 AM
    Maxola89
    Maxola89 [OP] Active Member
    Norton, VT
    2000 Tacoma 4WD Short Bed
    2.7 swap for a 2.4
    i just swap my 2.7 for a 2.4 everything fit perfect except for the individual coil pack that go on the spark plugs, the coil packs came off the 2.7. The 2.4 came with plug wires and i was hoping the coil packs would fit the 2.4 but they didnt. So what should i do or should i install a distributor with the plug wire.
    p.s. the coil pack were connected right off the wireharness so i have no plug ins for a distributor.
    :confused:HELP me out pls.....
  2. Sep 23, 2009 at 6:16 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW.
    Only thing I can think of is swapping the ECU from a 2.4. You need the right ignition for the engine.
  3. Sep 23, 2009 at 6:21 AM
    Maxola89
    Norton, VT
    2.7 swap for a 2.4
    i knew i might have to swap the ecu but how about after, what do i o about the ditributor?
  4. Sep 23, 2009 at 6:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im not sure... I may not be awake enough yet to be able to give a viable solution, Ask 98tacoma27 (ben), and see what he says.
  5. Sep 23, 2009 at 6:29 AM
    98tacoma27
    Ben
    Not Beech Creek
    What year did the 2.4 come out of?
  6. Sep 23, 2009 at 6:30 AM
    Maxola89
    Norton, VT
    2.7 swap for a 2.4
    would the individual coil packs work if i replace the ecu with a 2.4 one?
  7. Sep 23, 2009 at 6:31 AM
    Maxola89
    Norton, VT
    2.7 swap for a 2.4
    i had a 2000 2.7 and i replaced it with 2000 2.4
  8. Sep 23, 2009 at 6:36 AM
    98tacoma27
    Ben
    Not Beech Creek
    I am just making sure I have all the info before I give you a definitive answer.
    From what you said above, the 2.4 has a distributor on it?
  9. Sep 23, 2009 at 6:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    See thats screwing me up....I thought they were all coil for the 2000 year? My 2.7 was. :confused:
  10. Sep 23, 2009 at 6:54 AM
    98tacoma27
    Ben
    Not Beech Creek
    As far as I know they were. There was a difference though. Some had two coils, one for two cylinders. They still utilized plug wires. The coil packs were on the front left of the motor. You can see about/aboot where they are on this picture.
  11. Sep 23, 2009 at 6:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    Here is another view. This is a 98 2.7 BTW
  12. Sep 23, 2009 at 7:23 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yea, you should have two of these somewhere on the left front of the motor.
  13. Sep 23, 2009 at 8:22 AM
    Maxola89
    Norton, VT
    2.7 swap for a 2.4
    ben, the 2.4 came with those on the left front motor but i have no plug in from my wire harness to plug them in i can up load some pics to show you wat i mean if you want
  14. Sep 23, 2009 at 8:25 AM
    98tacoma27
    Ben
    Not Beech Creek
    Pics are always helpfull. Do you have the hareness from the 2.4 also?
    And those would be where the plugs attach to.
  15. Sep 23, 2009 at 8:28 AM
    Maxola89
    Norton, VT
    2.7 swap for a 2.4
    yes but it was cut right before it goes in the dash brb
  16. Sep 23, 2009 at 9:15 AM
    Maxola89
    Norton, VT
    2.7 swap for a 2.4
    ok theres a few i put up
  17. Sep 23, 2009 at 9:20 AM
    98tacoma27
    Ben
    Not Beech Creek
    Also, Which of these stickers do you have? It should be located in the engine compartment close to the radiator or in the drivers side door jamb. I can't remember which.
  18. Sep 23, 2009 at 9:38 AM
    Maxola89
    Norton, VT
    2.7 swap for a 2.4
    here it is
  19. Sep 23, 2009 at 10:52 AM
    98tacoma27
    Ben
    Not Beech Creek
    Cali emmissions. Ok. I will have a definite answer for you in a few. Just need to verify a few things.
  20. Sep 23, 2009 at 12:39 PM
    98tacoma27
    Ben
    Not Beech Creek
    Ok, here is what I have found both good and bad news.
    Bad- The ECU's for the Cali emissions are different from the FED emission ECU's. The easy way to tell is the coil packs. One coil pack per plug indicates a Cali emissions (like your 3rz). The FED emissions have one coil pack per two spark plugs (like your 2rz).
    Good- The Cali ECU for the 3rz and 2rz seem to be interchangeable. But there is one exception. The 3rz ECU monitors the EGR temperature where as the 2rz ECU DOES NOT. This wil not matter as long as you used the 3rz EGR vavle.
    So what does this mean to you?
    I think you have an easy fix here.
    You can purchase the the individual coil packs for the 2rz. They will look similar to the 3rz. Install them and it should work with the exsisting 3rz harness.
    The pinouts of the Cali ECU's and the color codes of the wiring match. The difference between the 2rz and 3rz mechanically is the compression ratio.
    :thumbsup:
