Chirping sound
Discussion in 'Technical Chat' started by iamjustifyd, Dec 20, 2009.
  1. Dec 20, 2009 at 9:18 PM
    iamjustifyd
    iamjustifyd [OP] Well-Known Member
    Sherry
    new orleans
    2001 PreRunner SR5
    New here and looking for an answer to a chirping sound I've been having. From under the truck, when I give it gas there is no chirping but when I let off the gas to slow down or hit a steady speed there is. Loud especially when I start it up. Doesn't do it all the time but most of the time. Little researching I've done...could it be the U-joint needs some grease?
    It's a 2001 Prerunner, SR5, extended cab, manual trans. everything is stock about 66,000 miles. All maint. is kept up with and from what I've read the joints are supposed to be greased when I get the oil changed?
  2. Dec 20, 2009 at 9:20 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
  3. Dec 20, 2009 at 9:37 PM
    01tacoprerunner
    01tacoprerunner 01 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner
    Its the U-Joints on the drive shaft, i had the same thing on my 2001 prerunner, Just clean them off and grease them with a grease gun.
    THeres one at the tranny, 3 in the middle where the 2 pieces came together and then 2 at the axle, doesnt take to long to do, just make sure You do it right and it should fix it.
  4. Dec 20, 2009 at 9:52 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Lol thats my bad, I figured he was new and we may as well point him in the right direction right off the bat. I was hoping it didn't offend him. If I would have been certain of the answer I would have given it right off the bat but my info was as good as his speculation.
  5. Dec 21, 2009 at 5:24 AM
    iamjustifyd
    Sherry
    new orleans
    2001 PreRunner SR5
    Laugh..no offense at all. I'm also on some motorcycle forums so know how the kidding around goes. I played hookie from work today and this sounds like something I can do. Thanks
  6. Dec 21, 2009 at 5:30 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Make sure your tensioner pulley is not seized up. I just pulled mine off for that reason. at low rpm it was quiet, but once the rpm's got higher it sounded bad.
  7. Dec 21, 2009 at 5:33 AM
    iamjustifyd
    Sherry
    new orleans
    2001 PreRunner SR5
    One more thing, when I'm getting the oil changed should they be doing this? Think I'm gonna start doing my own oil changes again.
  8. Dec 24, 2009 at 10:05 AM
    4low2go
    4low2go Well-Known Member
    Coatesville, PA
    10 RC 4x4 5sp MGM
    Curt hitch, OBX Shift
    If you're not moving when you hear it, it's not the U joints, but they could use grease at 66,000. A slipping belt or throwout bearing for the clutch may be the issue.
  9. Dec 24, 2009 at 12:24 PM
    iamjustifyd
    Sherry
    new orleans
    2001 PreRunner SR5
    I went for a ride, a few times, not making the noise anymore. Go figure.
  10. Dec 24, 2009 at 8:11 PM
    4low2go
    Coatesville, PA
    10 RC 4x4 5sp MGM
    When you hear it, step on the clutch, this will load the throwout bearing. If the noise continues at the same pitch, we can rule out the TB.
  11. Dec 24, 2009 at 9:03 PM
    Dane-Taco
    Dane-Taco Well-Known Member
    Justus
    Wasilla, AK
    '10 Doublecab 4x4 TRD Off-Road
    Bilstein 5100s set at 0, OME 886 coils, Camburg Ball-Joint UCAs, 295/70/17 Nitto Trail Grapplers on 17x9 Moto Metal 957s, 2" Tuff Country AALs, SX8000 Gas Shocks (Rear), Homemade Satoshi Grill, Redline Hood Struts, Locker Anytime Mod, Map Light Mod, Diff Breather Mod, Fog Lights Anytime Mod, Extra Bed D-Rings, Sock's Badges and Decals, PIAA 520's, Illuminated 4x4 Switch Mod
    My '99 did that. It chirped while in gear (manual) and released the throttle but stopped while accelerating. I had people tell me it was the catalytic converter.
  12. Feb 10, 2010 at 8:07 AM
    iamjustifyd
    Sherry
    new orleans
    2001 PreRunner SR5
    Know what it was...something I would not think of. The brakes needed cleaning, they would close but then not open back up all the way sometimes. I know I have to clean the brakes on my bike sometimes too, just never thought of it with the truck. Ever had that happen? And thanks for all the replies.
  13. May 14, 2011 at 6:37 AM
    darkwater27
    darkwater27 New Member
    David
    Winters, Ca.
    01 PreRunner SR5 3.4-V6
    I had the same issue... chirping sound at highway speed after letting off the gas.... dealership couldn't find it.....*** it ended up being the drive shaft center support bearing****. Sound went away after a new install.
    I also installed new U-joints while I was there for good measure.
